Re: Why won't my PC download my pictures from my camera?
A number of things may prohibiting your camera from downloading the pictures to your computer. Here are a few suggestions that should point you in the right direction:
Ensure that all cables are properly secured from the computer to the camera.
Ensure that the memory card has not been dislodged from the camera.
Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Scrap the camera! Kodak hasn't and won't address the problem. Most picture download software won't recognize the camera. The only solution is to remove the memory card from the camera, put it in USB adapter and treat it like a flash drive. Cumbersome. Awkward. Stupid. After you scrap the ****, tell your friends so they don't make the mistake of buying a Kodak.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
If you insist on having the Kodak software, you may download it from here.
