Buy a CD Lens Cleaning Disc from Walmart. Run that a couple of times. If that doesn't fix it send it back.
Oh, it a portable Sony Disc Player clone. That means it has to be 15 years old or more. Actually, I found the date '18/6/2007'. It's a new 14 year old device that has been in storage. Emerson are a bargain basement brand and generally lack quality..
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
if your sound system gives you Desk Error or Desk Read Error, try cleaning it with a lens cleaner, they can be found in many forms in the market. If the problem still insists then your system's lens ( the part which read the optical discs like DVD's CDs etc.) need to be checked by a professional technician, probably would install a new lens on your system.
You can comment if you need more clarifications. Best of luck
Since the receiver eventually works, the delay circuit is failing. This is a circuit that allows the power supply to settle down before kicking in the output relay. This prevents the "pop" that was sometimes heard on older units. This should be a simple and inexpensive repair probably requiring the replacement of a couple of small capacitors in that delay/protection circuit.
