Question about Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW
Brother MFC not printing in color
New machine, won't print color except for the test Page!
Posted by SteveC on
Bill Boyd
    Top Expert:
  • Brother Master
  • 53,814 Answers
Go into printer properties and set the colour as default.
normally when you go to print something there is a tab section that will get you there before you actually press print
Posted on May 24, 2015
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
Prints out blank pages, won't test print, new ink, cleaned multi-times, still blank!
Silly question from my side: have you removed the tape covering the nozzles of the cartridges? Is it original Brother cartridges, or is it compatibles?
Aug 23, 2011 | Brother MFC 490cw Color Inkjet...
Im only getting balck and yellow i have a mfc 5890cn printer
Try to print a test page, if this comes out in black in yellow take out the cartridges and make sure the plastic is taken off the bottom and pop them back in. Do a test page again. Does it now print in colour and are there any errors on the machine or pc? i.e. out of ink?
Aug 17, 2011 | Brother MFC-5890cn Color Flatbed...
Brother MFC-685 will not print in black, not even on test page. But will print when i scan print
You almost certainly have a defective printhead. When you make a color copy or print, the machine makes black by mixing your color inks.
If the machine is under warranty take it to an authorized service center (listed on Brother's web site) for free repair. If it's just barely past warranty, call Brother's Customer Support and plead for mercy. They often bend their rules to help a just-past-warranty customer.
If they won't cover it, steel yourself for bad news. The parts are expensive, and the required updates and adjustments are a time-consuming pain. You'll probably be told it costs more than a new machine. Good luck.
Oct 21, 2010 | Brother MFC-685cw InkJet Printer
Doesnt print in black
Go down to the 6th paragraph of this page:
http://www.slate.com/id/2198316
This seems to be a big problem with Brother and HP printers. Try marking out any area on the cartridge that could be read with a sensor, you might get lucky.
Jun 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
My brother mfc-240c doesn't print black. I replace the black with a new cartridge as it still wouldn't print black. I also tried to clean all the colors numerous times, but to no avail. I don't know what...
Wow, something similar just happened to me the other day, my black ink ran out & when I replaced it, it just wouldn't print, I kept trying to print things and it sounded like it was printing but then it would just shoot out a blank page of paper (I was trying to print BLACK). So, I went to the Brother website for troubleshooting tips and it said to make sure I had the ink cartridges installed properly so I took the black cartridge back out (it WAS installed correctly, but I was willing to try anything at this point), so I took it out, gave it a blow, like how you would blow on the old Nintendo game catridges when they did not work-I'm not sure if this did anything at all but it's what I did) and then I put it back in). The machine asked if had just replaced black I said "Yes", then it did another "cleaning", as it does when you replace any cartridge. Then I went in the menu to have it print out a "test page" (the instructions for this were in the troubleshooting tips on the website), the test page printed out with NOT all the little black squares as IT SHOULD BE so when it asked me if the test page was ok, I said "NO", then it did ANOTHER CLEANING and I did another test page, this time it worked ok, then I was able to print.
So, bottom line is, maybe take the ink out, make sure you installed it correctly, put it back in, print a test page, if the test page does nto come out right, then tell it it is no good by selecting "NO", then it will do another cleaning and then maybe it will work, if not, then check for more troubleshooting tips on their website, good luck.
Jun 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
No print at brother mfc-24c
"Machine Error 50" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
However, if that doesn't work, the error is mechanical, and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a brother mfc 3240C. I have changed the
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Apr 23, 2009 | Brother Office Equipment & Supplies
My Brother MFC 210 C printer will not print in yellow.
i cannot print the documents that i want ,,the printer cannot recieved the documents but it can copy.
Feb 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother Wireless Color Laser MFC-9340CDW All-In-One MFC9340CDW Logo
564 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
