Question about Health & Beauty
My lower leg was run over by a car, told no broken bones ,4 days later having extreme pain, burning, and blisters around ankle, with redness and hot touch, numb toes , now pain back of my knee.
Posted by Brandy Ferguson on
rhodesworks
    Top Expert:
  • 3,157 Answers
Go to the emergency room immediatly.
Posted on May 24, 2015
  • 18,440 Answers
The compression of the muscle has caused "compartment syndrome" In other words the swelling is causing damage and you need to seek medical attention right now if you want to save that leg.
Pain in back of ankle
go see your doctor
could be a tendon, or stress fracture in a bone
Aug 27, 2018 | Health & Beauty
To relieve the pain in my lower leg and ankle, while waiting for Surgery
what is the surgery for
if is not for a leg problem then I suggest that you get to a doctor fast as what you describe could be a blood clot in the leg and that is very dangerous
Dec 09, 2017 | The Health & Beauty
How do I stop my ankles and feet to swelling after being sun burnt
Hello Anne.
Since this is a Q & A about cars and trucks,,, I will venture off topic..
This is serious and therefore should be evaluated by a physician. When you go to your doctor's appointment, be prepared to discuss the following possibilities. If the ankle swelling started just after the sunburn, it may be due to an inflammatory reaction as the skin tries to heal. A sunburn is a first degree burn but it still causes local inflammation and pain. As the body mounts an inflammatory response, the capillaries in the area dilate and become leaky. This process can cause localized edema and swelling, which usually resolves on its own over time. However, not every sunburn causes this reaction, so if yours is severe, you should see a physician. The reason you get extreme pain when you stand still is because the blood is pooling in your lower legs causing the swelling to increase. It is so painful cause the tissues are ripping apart to create room for the 'blood pooling' or tissue swelling. The most sensitive areas are the shins cause the tissue is tightly attached to the bone. That is why when you sit down or lay down it subsides or goes away. The body is not "upright" causing gravity to pool the blood in your lower legs ankles and feet can also be due to lymphedema. Lymph fluid travels up through vessel and is filtered through the lymph nodes of the body. Any issue with the lymph nodes or vessels in your leg can cause the fluid to pool in lower areas of the leg. If you have ever had lymph nodes in your abdomen, pelvis, or legs removed or irradiated, you should see a doctor very soon. Another possible cause of your problem, is your body retaining too much fluid overall, which can be manifested as swollen ankles and feet. This condition, called pitting edema, can affect people who have problems with their heart, liver, or other body systems. When fluid builds up in the legs, it can also build up in the lungs and other critical organs, so it is important to have this issue evaluated immediately. I strongly recommend that you make an appointment to see your primary care doctor ASAP!!, and he or she can refer you to a specialist if this becomes necessary.
Jun 16, 2017 | Cars & Trucks
What are the long term effects of a brown recluse bite, four years after bitten?
Regardless what you have been told, osteoarthritis is a result a RAGING mineral deficiency ... so your body is feeding on your own bones to get the minerals it needs!
Ever heard of Dr. Joel Wallach, or his publication, "Dead Doctors Don't Lie"? Listen to the whole thing on YouTube.com, and start eating 6-10 SOFT SCRAMBLED eggs per day, and take some glucosamine sulphate!
May 09, 2017 | Knee Health & Beauty
How to fix a broken bone
With no medical knowledge don't start this. Not only you cause unnecessary pain, but you risk it will never grow in place and your friend will be crippled for the rest of his life.
When you are far from all medical help, you should have learned first aid and should pull the broken part so when released it will come straight. and then it should get something like sticks around the leg and the sticks should be kept together with bandage. I once did it myself, after a motor accident and the surgeon was not pleased. They had to operate me for 3 hours, because there was muscle between both bone parts. Took me a year to recover from that. And I'm not joking.
Apr 17, 2015 | Human Touch Health & Beauty
I used hot to trot on my legs. Part of my legs are beat red almost like a really really bad sunburn. No blisters or real pain. It has been like this for almost a full day. Should this have happened? ...
Make sure your skin is mosturized before using it. Also a base tan is recommended before use. It is not intended for sensitive skin, so you should have tried it in a small area before using it. The color will last for several days, between 4 to 7 depending on your skin. This kind of products don't work well for most people.
Apr 24, 2011 | Designer Skin Hot To Trot Hot Tingle...
My two week old Sanyo Mirro started to burn in my coat pocket, I quickly remove the battery...No damage was done "inside" the battery compartment, but the outside bottom right corner (phone...
I have no fix for you but my Sanyo HP700 burnt my leg and now it is infected!!! had to go to the doctor and have antibiotics and cream. There was a huge blister and it got infected in a matter of two days even tho I cleaned it and applied Polysporin triple. There is a huge red welt around the burn about a 4" diameter. [email protected]
Jan 17, 2011 | Sanyo Cell Phones
Health & Beauty Logo
318 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
