Question about Nikon D70s Digital Camera
Fee error message in monitor screen flickering, will not allow pics to be taken
Posted by Erna burger on
Radix Veghel
  • 4 Answers
My D70s gives error FEE on aperture display, when a lens is mounted with manual aperture ring. This ring should be locked on smallest aperture.
The body closes the aperture just before taking a photo, but a manual (mechanical) setting could avoid that. You can choose the aperture with the front wheel on the body.
Posted on May 26, 2015
  • Cheryl Carpenter
    Cheryl Carpenter Aug 26, 2016
    Even when setting the aperture as instructed in the manual the message and lack of function persists.
    In my case the camera worked perfectly with the lense and then suddenly started giving the fEE errors message.
Flickering monitor
sounds to me the screen is out try another one see if it comes on then
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
There is an error code FE E which will not allow pics to be taken. It shows up when the camera is turned on and when look thru the view finder, it also shows in the bottom.
This is a Nikon SLR error for something is broken. Here is a link. http://www.loeki.tv/log/archives/85-FEE-error-on-Nikon-DSLR-fixed.html
May 02, 2010 • Cameras
Trying to get rid of flickering on screen. now an
Flickering is caused by the incorrect refresh rate being used by your graphics card, go into the graphics settings by right clicking your desktop and choose the correct resolution and refresh rate dependant on the screen size and options. TRYING ALL THE OPTIONS DOES NOT CAUSE ANY DAMAGE TO YOUR PC OR MONITOR. Just pick the setup that suits you.
2helpful
Flashing E91:01 on screen
Hi!
Try initializing the camera. Error 91 is a flash error in Sony cameras. It is probably a dead flash fuse on the motherboard (most common problem) or a faulty flash board. If you have a multimeter, I can help you locate and test the fuse and if you have a soldering iron - even fix it. My e-mail is [email protected] Otherwise, you should contact your local Sony service center or other local camera service center.
Hope this helps!
Tom
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Chimei CMV 938D 'Out of range' error message only when using DVI Connector on specific resolution and color depth
I know this sounds obvious but- I had the same problem, and turns out the cord want plugged in quite properly at the back of the monitor. This may not fix every problem, but, I suggest you check the cord pligged in at the back of the monitor is firmly in there and restart, then if you still get the problem, contact the company.
Error write
format the memory card in your camera and then use it. it will work fine. if not try different memory card to ensure what is the original problem
Dec 24, 2007 • Cameras
Nikon D70s Digital Camera Logo
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
