Whirlpool DU1055XTS Built-in Dishwasher Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool Quiet Partner I. HELP Drain light flashing
I have a whirlpool Quiet Partner I. There is a light that is flashing on "Clean". So I pressed the Drain Cancel Button and nothing happens it just tries to drain and the light continues to flash. If I hit Resume/Start nothing happens. Please help this is driving me nuts. It's like the stupid thing is frozen, and I already unplugged and tripped the breaker to reset
  • hcb149 Jul 11, 2009
    THANK YOU SO MUCH!!!!!!!! The solution completely fixed my dishwasher. I can't thank you enough. Wirlpool told me it needed person to come out and possibly parts.
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Jul 11, 2009
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734266
Points
22413
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this fixes your problem.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
588
Points
I found whith mine that the ribbon cable that branches off to the time display was out of track and had corrosion on it, cleaned and put back on track and everything is running good.
Whirlpool quiet partner ii clean light flashing 7 times. I installed a new heating element and reset the code, and it still flashes 7 times
Check the main control for the heater relay, this may be faulty and the cause of your issue. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
44helpful
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
1helpful
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
1helpful
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 • Dishwashers
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
3helpful
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 • Dishwashers
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
