Golds Gym Powerspin 290C Upright Bike Logo
K
Kathleen Posted on May 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I plug in ac adapter - Golds Gym Powerspin 290C Upright Bike
Techmotionusa.com
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 163 Answers
  • Posted on Jun 24, 2015
Techmotionusa.com
Expert
Level 2:
New Friend:
Cheetah:
Answers
163
Questions
0
Helped
84591
Points
319
There should be a power jack on the unit, sometimes on the console, but also check the lower front, and lower rear of unit. Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Power adapter i can us
What does a power adapter do?
An AC adapter, AC/DC adapter, or AC/DC converter is a type of external power supply, often enclosed in a case similar to an AC plug. ... AC adapters are used with electrical devices that require power but do not contain internal components to derive the required voltage and power from mains power.
OR
power adapter. A power supply for electronic devices. Also called an "AC adapter" or "charger," power adapters plug into a wall outlet and convert AC to a single DC voltage. Computers use multiple DC voltages, and the power adapter is the external part of the power supply for a laptop.
https://www.pcmag.com/encyclopedia/term/power-adapter
Model 23951.0 power is not coming on
Reset the AC adapter by following these steps:
  1. Unplug the AC adapter from the wall outlet for 15 seconds.
  2. Unplug the AC adapter from the laptop.
  3. Plug the AC adapter into a known-good wall outlet.
  4. Plug the AC adapter into the laptop.
  5. Check the LED indicator on the AC adapter.
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Regards,
joecoolvette
2answers
How do I get my computer to recognized my new ac power adapter?
The computer doesn't need any drivers to recognize an AC Adapter. If you have purchased the correct AC Adapter for your laptop then it should just work when you plug it in. If it does not then my guess is either you have received a faulty AC Adapter or the DC Jack which you plug into in the back of the laptop is bad.
I am assuming your battery is dead and when you plug it in and turn it on nothing happens?
You can also try taking the battery out and try to power it on with the AC Adapter plugged in.
The Dell Latitude D610 takes a PA-10 or PA12 AC Adapter. It's 65W or 90W
For 90 watt Adapter the output voltage on your AC Adapter label should read 19.5V and 4.62A
At least that's what the Dell brand reads so it should be close to that.
Laptop won't a hold charge when plugged in
Remove the Laptops Battery, Plug in AC Adapter... Is it able to Stay Powered On?? Slightly wiggle the Cord Near the plug end while plugged in... Does it still receive true power??? If So, Its Not Your AC Adapter Or Your DC Jack And You should Look into Replacing Your Laptops Battery...
If You Are Not Able To Power THe Laptop Using Just The AC Adapter When The Battery Is Removed, Then You First Need To Check/Test The AC Adapter using A Multimeter To See If You Have A Faulty Cord... If Cord Is Still Getting Correct Power Through To The Plug Tip .. Then You Will Need To Replace The DC Jack (the port where your AC Adapter Plug Plugs into on the laptop)
I HAVE A ASPIRE 5520 IT WONT START THE FAN STARTS AND THE DVD BUT IT JUST KEEPS ON LOPPING
I had the same problem but what you can do is...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
  8. If its not the batery or AC adapter you might have to send it to Texas, just go to www.Acer.com
Batteries AND ac adapter?
Make sure the ac adaptor ius the right polarity for the camera, negative outside plug and positive centre,also make sure the voltage output of the charger is correct 5 volts dc.You do not need batteries as well as the charger.
Top Golds Gym Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
