SOURCE: I have a 2000 Honda
When my alarm goes off, it usually happens when someone sticks their hand in the window to unlock the door. In order to turn off the alarm I close whichever door the person opened back, and unlock the door from the driver's side door. This usually turns the alarm off.
SOURCE: HOnda Accord EX 1998 ALARM
Have you tried putting your Valet (original keys) into the ignition and turning it to the II position?
SOURCE: False security alarms on a 2000 Honda Accord EX
A couple of ideas:
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: can't lock my Honda Accord as alarm goes off when locked
if you have a valet key, stick it it on the passenger side when unlocking door, so it wont alarm while you open the door hope that helps
The car alarm on your 2000 Windstar minivan
is wired into your van's battery. When you are making a repair to your
car such as a battery change out your alarm can go off. You can easily
disable the Windstar's car alarm by disconnecting the battery from the
alarm. The battery is connected to the Windstar battery's negative
terminal. Disconnecting the terminal from the battery will disable the
alarm.
