Question about Magic Chef MCD1611ST Microwave Oven
Microwave would cut off after a few minutes and then turn back on but now there is no power at all.
For the past few weeks if we use the microwave for more than a few minutes it would cut off. It would come back on after a few minutes. Now there is not any power to the microwave at all. I have tested the plug and checked the breaker. Both are fine.
Posted by Linda Morris on
Ashwin Kumar
    New Friend:
  • 27 Answers
There are few reasons for this fault, but the main is that you need to open your microwave oven and first check the Fan which is connected at the back which cools the magnetron.
If this fan fails thus results in magnetron being overheated and the thermal cutoff gets open circiut and shuts down whole power of your microwave oven.
Check your fan motor test it straight with direct power
Also check the thermal cutoff.
Let me know after you have done those checkups
Regards
Ashwin
Posted on May 24, 2015
5 Related Answers
Anonymous
  • 100 Answers
SOURCE: microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Posted on Oct 31, 2007
Anonymous
SOURCE: Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Posted on Jun 27, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
Anonymous
  • 130 Answers
SOURCE: no power to microwave all ready checked fuse box
the circuitry has probably gone bad, try plugging it into a different electrical outlet, but if that doesnt work, its probably dead. and it will be cheaper for you to replace than have serviced, unless its still under a warranty
Posted on Jan 15, 2010
baldo134
  • 75 Answers
SOURCE: I have a Magic Chef microwave MCO160UB. I was
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Posted on Aug 29, 2011
I put a mug of water in the microwave, left the room. Came back, and the room was filled with a burning electrical/plastic smell, no visible smoke. Now, the microwave completely powers off after 1 second...
Since there was no smoke, it's not a transformer. It's most likely a high voltage diode or magnetron. The magnetron would be over heating and opening a thermal cut out mounted to or near it.
Oct 19, 2013 | Samsung SMH9187ST Microwave Oven
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
We heard a "buzzing" sound and it stopped when I
I had a similar problem. Everyone said must be the magnatron or the fuse ....turned out to be a burned out (visually melted) thermal cut out switch ($12) on the top side of the microwave. Had to get down inside the top of the microwave. The cut out switch was tucked away right up against the the microwave box. Hard to diagnose your problem without looking at the unit in question though, could be several different things. However, my philosophy when it comes to repairs...start with the cheap stuff first!
Jan 10, 2011 | Frigidaire FMV145K Microwave Oven
My microwave shuts off after it has been cooking for only a few minutes. It comes back on shortly but if I try to use it it will cut back off again.
Microwaves have a thermal protection device that cuts out power and prevents the oven from overheating when it gets very hot (burning hot). If it (or some other part) is malfunctioning, it is likely that the oven needs to be serviced.
Replacing the thermal protector, may not solve the problem, but if you can feel (or smell) heat coming from your microwave it may simply be the symptom of another component failing.
Remember, while you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, let me know and I will point you in the direction of some good resources.
Oct 21, 2010 | Magic Chef CMV1000B Microwave Oven
My over the oven microwave turns off after a few
i would check your thermal cut offs inside he cabinet,there is a chance that your cooling fan is bad,even thought it may be turning it might not be turning at a fast enough rpm to proper;y cool the unit.
the last thing that i think would be bad is the control board.I hope this helps you get your microwave fixed
Feb 06, 2010 | Microwave Ovens
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Thanks
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
Magic Chef MCD1611ST Microwave Oven Logo
427 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
