Question about Philips Magnavox 51MP392H Rear Projection Television
Turn tv on no pic no sound nothing - Philips Magnavox 51MP392H Rear Projection Television
Posted by michael bethoney on
Tv turns on but has a blank screen and nothing happens.
If you think the back light is working then check out the main board since you have no pic and no sound.
Nov 12, 2015 | Televison & Video
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
No pic, just sound
Hi, you have not specified if your tv is still conventional tb that uses crt, or lcd
Jun 25, 2017 | Sanyo 42 in. LCD TV
My tv wont show a pic or sound. the green light comes on and it clicks but nothing. its a sony bravia kdl-55ex710. its happened before and my husband played around with the home button. it occassionly...
On the remote control to that tv, after the power is turned on, find and push the input button untill you have a picture. The input button switches where you are receiving your signal from, cable, component, video 1, vedeo 2,,etc,,,.
Hope this helps
Apr 19, 2011 | Televison & Video
I have a 47 lg lcd tv bought in 09. When i use hdmi for xbox 360 i get picture and sound but with ps3 no pic no sound. I just bought a sony bluray and get pic but no sound. I bought a lg bluray and get no...
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
Nov 08, 2017 | LG 47LF11 LCD TV
PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Nov 21, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY TV
how many times the led blinks?
Jul 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PS3 works on one TV but no pic/sound on Sony 100HZ. Tried soft reboot, messing with cables etc but nothing
try by pressing the button (on) from the ps3 when its turned off not the controller and hold it till it makes a sound after 5 sc i think. I had the same problem on 1 tv it worked and when i connected the ps3 to another tv nothing appeared
Dec 24, 2007 | Sony PlayStation® 3 (60 GB) Console
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
