Question about Disney Cosmo Communications Corp P600D Princess Dvd Player - cmop600d
Need set up instructions for model # WPP3915
How to play DVD on this tv
Posted by Charyll Ruggeroli on
Rm-995 instruction
That Sony remote may if batteries removed erase what it was programmed for (several minutes) and should have program instructions on it--if not try to Google the model number of the remote for "manual" which will among other things tell you how to do what you want---Sony on their consumer site may have that manual for free or direct you to a place that does.
Apr 11, 2012 | Televison & Video
When I play a DVD, it is in black and White. When I play the tv it is in colour. Can't get the DVD to play in colour!
You have one of several possible problems, ranging from best case scenario to worst case scenario:
A DVD video that is supposed to be black and white - try a different disc.
Some setting on the DVD player is set to monotone - check manufacturer's instructions
A bad set of cables connecting the dvd player to the tv - test a known good set of cables
A bad output on the DVD player - test DVD player with a different TV.
A bad input on the TV - try another input if possible, test TV with a known working video input.
Sep 17, 2011 | Computers & Internet
We have a Philips Magnavox Model #TP3284C101 TV and plugged in a Durabrand DVD Model #DVD1002 player to it. It will only play in black and white on this TV. But when we plug the DVD player into another TV...
It sounds like you have a standard problem.
Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
Check to see what is required and set the DVD player accordingly.
Hope that helps.
Dec 10, 2010 | Philips Magnavox 27MS343S 27" TV
I have philipd\s dvd player model no. DVP3126K/56.
Check with other DVD disks, see if it play,might have bad disk in that one,like scratches,cracks,or smushes.The disk u playing is a chamerical DVD Disk right?Not burn disk?Might just go in Ur DVD player just reset every setting back to the factory setting.
Oct 31, 2009 | Televison & Video
Sony rdr vx410 dvd player playing some dvds in black and white
  • DVD's are standard definition video sources. Number of lines output is 576 lines, whereas your HD TV set has 720 or 1080 lines. This difference may result in a poorer image. However some DVD players are able to “upscale” picture to obtain a very good picture. Check if your DVD player has the following connectors: YUV, DVI or HDMI. For more information, refer to the instruction manual of your DVD player.
  • Some HDMI or DVI featured DVD players also have an internal processor that can upscale pictures from a DVD to 720 or 1080 lines to provide an excellent picture from a standard definition disc to your HD TV set. Those settings are available from the setup menu of your DVD player. Please refer to the instruction manual of your DVD player.
  • If your DVD player does not have those connectors and only has a SCART connector, or S-VIDEO, or composite, there is not much to do to improve the picture quality. Just make sure that you are not using the cheapest cables and that the picture settings of your TV set are correctly adjusted.
  • Some high end TV sets have a picture improvement engine that can soften a noisy image. Make sure that it is activated from the setup menu of your TV set. Please refer to the instruction manual of your TV set.
  • If people and objects have weird white outlines around them. This may suggest that your TV sharpness is set too high. Make the correct sharpness adjustments from the setup menu of your TV set.
  • Make sure you use good quality cables and that your cables are not too long (less than 5 meters long).
Jun 15, 2009 | Sony RDR-VX420 DVD Recorder/VCR
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
TV is not recognizing the dvd player
The DVD player should be connected via either a scart socket or an HDMI socket. You then just press the AV button on the TV or in some cases it will switch when you press play on the DVD.
Video's haven't been tuned to TV's for years.
Oct 05, 2017 | Toshiba 20a43 20" TV
Unable to switch on DVD function on a Bush 14" combo
Switch on t/v press TV / DVD button on remote to ensure it is in TV mode. Select DVD by pressing
AV button once or by using input select menu
Press TV /DVD button until DVD RC appears on top left (The remote is now set to DVD mode)
Insert disc ensuring label is to rear of set and Auto play function will start
Oct 10, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Need help setting up DVD-VR375 with compatible SAMSUNG TV
if it has component (red, blue, green) cables, plug one set into dvd player's "in's" and tv sets "out's'. you may have to play with the tv channels to be able to watch movie. you just change channels, go from "3" backward until you find a picture and sound.
Sep 01, 2008 | Samsung DVD-VR357
VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Dec 17, 2007 | LG 42LC2D 42 in. LCD HDTV
Disney Cosmo Communications Corp P600D Princess Dvd Player - cmop600d Logo
166 people viewed this question
Top Disney Televison & Video Experts
Lee Hodgson
Lee Hodgson
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
