Garden Logo
thas kanda Posted on May 21, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have homelite lawn mover (ut13126) when I measure bat 24v(also white&black 24v)when I press the switch the blade spin very slow. (green&white 2.4v) the indigater red light. how to fix problem?
Bill Boyd
Level 3:
Top Expert:
  • Garden Master 53,816 Answers
  • Posted on May 22, 2015
Bill Boyd
Garden Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925559
Points
172802
Check the battery condition as it may have 24 volts but very little when the motor is trying to spin
check that the blades spin freely by hand to ensure that the motor is not seizing up
I have yard work lawn mover runs with 24 v battery. its not running in full speed. and doesnt cut grass. its blades run at a very slow speed. do i have to change battery
I have a Green Works 40V which came with two Rechargeable batteries. I always keep one fully charged. The charge can dictate the power you are getting. Fully charge your battery. If that is not the cause, replace it. Examine the under side of the mover, with the battery REMOVED. Make certain there isn't anything in the way of the blades moving freely. Good luck.
Sep 23, 2018 • Garden
2helpful
2answers
I have a Homelite 24v cordless lawn mower model UT13122 that doesn't run
im not exactly familiar with this model , but a few of these new fangled lawn mowers have come my way in the past , what I've found on most of them there susceptible to the same problems the power mower have , they have safety switches and hold handles that do malfunction , also they do have battery's and those are susceptible to bad dirty connections
What can cause my Homelite cordless lawn mower UT13126 to stop after 3 minutes when the battery is fully charged
Your rechargable battery may no longer accept a full charge if it is old.. Get it tested at a garage.
Possibly the battery is OK, but the lawnmower blades are too stiff to turn and the battery soon gives up. Check blades can rotate freely, and have not got entwined grass or string etc wound around the shaft
Worx 17'' Cordless Lawn Mower (Model WG787). I've got a barely three month old lawnmower and the battery is fully charged yet the blade only barely spins. Seems to be virtually no power despite the charged...
The batteries are defective in this unit. It should be returned to the dealer that you purchased it from and get exchanged, or your money back. Another way to test this mower is to charge the batteries fully, then test them. If they are truly fully charged, run the mower until it slows down, and test the batteries again. If they are still charged, (unlikely) then the problem is in the motor itself and still should be returned.
1helpful
I have a Homelite Z830SB Brushcutter. I use it with the blade attached rather than the line, for cutting. It starts fine, but it does not engage (i.e. the shaft does not spin...so there is no rotation in...
the inner shaft could have broken, which is the case a lot when using the blade vs the string remove the shaft from the motor, and spin the inner rod and see if the blade turns, if it does check the end of the rod and see if its damaged in anyway , if the blade doesn't spin, the shaft has broken and will need replacement
Transparecy issue
+24 VDC power is failed. Status Code 102-319 is displayed after 116-325 is displayed.
+24V LVPS is failed. Perform following:
Remove Rear Cover (REP 14.2).
Remove cover from +24V LVPS (PL 9.1).
Disconnect P502 on +24V LVPS (Figure 1).
Check that power is switched off. Measure resistance of fuse on +24V LVPS. Resistance is 1
ohm or less.
if no Replace +24V LVPS (PL 9.1).
if yes Switch on the power. Measure the AC voltage between the white and black wires in P2 on the
+24 VDC. 110 or 220 VAC is measured.
Need to know color code for 220VAC receptacle, so can wire up an output cord. Had no cord with the generator. Have LRE 5500 portable generator. Have new 4 prong plug.
Hello Arthur,
For 220vac, you will have 2 blacks or Red and Black (line). The white is neutral, green / bare is your ground.
If you look closely at the plug, the contacts for the line will have either black screws, or be labeled as L1 and L2. Neutral will have a white or silver screw, may be labeled as N, and the ground will be green or silver, labeled as Ground, Gnd, E, or Earth.
I have a troy bilt riding lawn mover, it cuts the grass uneven, changed blades thinking it was the problem, but it wasn't. do they have any kind of adjustments for the blades?
The best bet is to work on the deck with it removed from the tractor. You may find the bearings are out in one of the spindles. Quite often someone hits something and the deck housing is bent where the spindle bolts to it. Use a tape measure and measure the distance from the deck to the blade. Compare the two spindles (3 if it's 3 blades) . You'll find one spindle is tilted so that it is not 90 degree to the deck. What I do is once I've located the offending spindle, and which direction it is tilted, I remove the blade, slide a piece of pipe about 4' long over the spindle (usually 1-1/2 or 2" pipe) so it clears the hub and bend it. Then I reinstall the blade and measure it again.
Jul 18, 2010 • Troy Garden
1helpful
Black&D'er CMM1200 24V is running very slow unable to chew grass
Sounds like a battery problem, you could have a defective cell which is causing a very low voltage to be sent to the motor which = slow spin.
Yes the charge indicator could be related.
You can take the battery apart and find out what type of cell it is and have it replaced...but personally I hate cordless lawn mowers for this exact reason so I would go but a manual push or a gas model.
76helpful
5answers
Battery won't charge, 24v charger doesn't light up
Original battery is 130$+, or you can buy replacement for cheapest price (work the same). So, depends from the wallet, choose one... I found them on amazon, take a look:
1. cheapest one (about 30-40$): Amazon com 12N9 4B1 battery
2. Original one (130$+): Finally charging for our multi device world
I hope this was helpful. cheers
Apr 25, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
