Question about Smith Corona Office Equipment & Supplies
Is there a special ribbon for smith corona 450 to erase
Posted by Harold Lee Hill on
Mister Danger
  • Smith Corona Master
  • 5,631 Answers
Smith Corona 21000 Correctable Typewriter Ribbon 2 Pack
Presume thi is what you are lookin for?
Posted on May 22, 2015
How to change ribbon of my Smith corona clipper typewriter
Hi Claire, The link below is a short youtube video on how to change a 1960s smith corona type writer.. Also you can click any link on the right side showing the same with other smith corona models, I hope this helps...
https://www.youtube.com/watch?v=PSTmerh6s6M
Mar 30, 2016 | Smith Corona Office Equipment & Supplies
Smith Corona-Model5 5P uses H ribbon. Spellright-correcting. Dictionary. Needa manual and ribbons.If you can help call 423-344-3516.
Smith Corona 5p Series Electronic Typewriter Parts ' Model ...
www.searspartsdirect.com/partsdirect/part.../Smith-corona.../0544000
Shop for Smith corona Smith Corona 5p Series Electronic Typewriter repair parts for model 335DLE(5ADF) at Sears PartsDirect. Find parts, manuals & diagrams ...
Mar 05, 2015 | Smith Office Equipment & Supplies
Silver sterling manual smith corona ribbon keeps falling off
you may have place the ribbon spools so they are unwinding instead of winding up the ribbon. The left spool turns counterclockwise and the right spool turns clockwise. Make sure the ribbon winds onto the spools when turned in those directions.
Nov 17, 2010 | Smith Corona Office Equipment & Supplies
Have a Smith Corona Electra 110. The ribbon doesn't turn, whether it is set to go one way, or the other. The side that's driving the ribbon makes a little **** with the keystroke, but goes back to starting...
Make sure that the ribbon has been intalled into the reverse guide forks on either side where the ribbon comes out of the spools. The ribbon should have a rivet in the fabric near the end of the ribbon so make sure you have the proper ribbon. The machine may require lubrication. You might also try taking the ribbon out and moving the R side to the Left just so you can type a little bit. Thsi may loosen the mechanism.
Nov 04, 2009 | Smith Corona Office Equipment & Supplies
Smith corona electric typewriter H series ribbons and eraser
Is the ribbon correctable? The leader and take up spool should be orange or yellow if not tou have a non correctable ribbon.
DickyO
Nov 05, 2008 | Smith Corona Office Equipment & Supplies
Smith corona xd 6600
The ribbon is a one time use ribbon, Replace the ribbon cartridge with a new one.
Feb 01, 2008 | Office Equipment & Supplies
Fitting new ribbons to smith corona 100 electric typewriter
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
Oct 28, 2007 | Smith Corona Wordsmith 100 Typewriter
194 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
