Question about Watches
I have a frenzy s492 model do I need two batteries
I am replacing the batteries on the watch. Any instructions for me to follow
Posted by walter mifsud on
johnny rebel
    Top Expert:
  • Watches Master
  • 10,875 Answers
Replace all batteries
Posted on May 20, 2015
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Frenzy watch #FRZK1103 light up function no longer works, even after replacing battery. Is there a simple fix?
No simple fix, you will need a watch repair shop to fix this, but make sure you get a repair estimate, it may shock you.
Dec 07, 2014 | ACCUTIME WATCH CORP. Frenzy Ladies Watch...
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
Aug 16, 2014 | Coleman Mens Digital Dual Time Sport Watch...
I have a Casio 2688 atomic watch and lately it does not hold a charge for a long period of time. It will recharge and then quit within a day.It will hold a medium charge for about 24 hours at most, but...
You likely have a dead battery. Follow the instructions on this web site http://forums.watchuseek.com/f43/how-change-ctl1616-rechargeable-battery-41076.html
it is clear and covers most casio models. Watch closely for the springs when taking your watch apart. You can order the battery online (the best option) but most people that use a standard lithium battery seem to have no problem.
Nov 23, 2010 | Casio PRG-40T-7 Pathfinder
The battery on my Casio Waveceptor watch - model 4723 - has just been replaced, but the jeweller did not know how to reset it to the correct time. I have downloaded the user operations guide, but the watch...
Your watch probably needs a reset after the battery change.
Take the back off the watch. Examine the movement carefully - you should find a small electrical contact point marked 'AC' (which could be quite small). To perform a reset you will need to temporarily connect 'AC' to the '+' terminal of the battery (basically, the upper side of the battery). If you have some fine point tweezers they are ideal, but a bent paper clip (not a plastic coated one) will do.
Be very careful not the make metal contact with any other part of the movement!
Place one end of the paper clip on the 'AC' contact and, for 3 seconds, place the other end on the battery '+'. As watches sometimes need to be reset twice, there's no harm in repeating the operation while you have the back off the watch.
Once successfully reset, you should have no problem with setup and the watch should behave normally.
Hope this helps.
Aug 29, 2017 | Casio Watches
I have a Timex I bought in 2007 on the back of the watch it says CR 2016 cell and WR 100m. The time started to catch on a certain time and stopped the date from working properly, I need to know how to...
You should probably replace the battery using a new CR2016 battery. Let the watch set a while without the battery to help it reset. WR 100m just means the watch is "Water Resistant to 100 Meters". Then use the following info.
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Sep 01, 2010 | Watches
Just purchased timex 1440sport watch with heart rate monitor strap and there is no date/time, etc. showing on screen and indigo lite does not glow. Battery dead or watch needs to be activated??
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.If you can not sort the problem after following instructions, you may need to replace battery. Rate me, please
Mar 27, 2010 | Timex 1440 Nylon watch
Besides the battery is there something else that would cause my Movado to stop working. I just bought a new battery and it isn't working. I'm hoping that the new battery is bad.
Sometimes there is a special procedure to be followed when replacing a battery.
I looked at the user instructions for Modavo (generic instructions for their watches, not one for your specific model) and I found no special instructions for replacing a battery.
The last resort is to do to a Modavo stockist and explain the situation and ask for his help.
You can find a list of stockists on their web site (Modavo.com). In the menu on the left is "find a retailer", click on this to find your near shop.
Feb 01, 2010 | Movado Eliro 0605377 Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
42 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
