Cannot get cd drawer open? - Audio Players & Recorders
  • 7,733 Answers
Try to open by using the eject funtion on my computer.
Go to:1-My computer
2-On the CD/DVD drive do a right click and select eject.
If this work you need to replace the PC eject button.
Posted on May 20, 2015
Denon CD Player Drawer won't open
This problem can be due to a defect in the player mechanism or binding in the drawer travel path. You may be able to find and correct the binding problem.
Jan 29, 2015 | Denon Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
How to open the cd drawer when the open/close button won't
Remove the lid, you will probably have to remove the whole cd mech and turn the gear underneath with your finger
May 22, 2014 | Marantz SA8260 CD Player
I can't open my cd drawer
If you look on the drawer you'll see a little hole. just push a pin in the hole and the drawer will open
Nov 02, 2013 | Computers & Internet
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Most CD's have a small hole in the front of the drawer cover. This hole can be used to open the drawer, straighten out a large paper clip (wire style). About 2" should be enough! Put he paper clip end thru the hole perpendicular to the front (straight in). You will feel resistance at about 1/2" to 1", pressing firmly (don't jam it in), the drawer will start to open as you press the right place, gently pull the drawer open. If something is jammed inside, removal and possible replacement may be required. If you don't feel confident in opening the case, don't!
Oct 20, 2008 | Compaq Presario X1000 Notebook
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Jul 16, 2007 | Teac GF-650 Turntable
365 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
