Question about Gaggia Titanium Espresso Machine
My Gaggia Titanium is still in descaling mode after 24 hours. How do I stop it?
    Habit-Forming:
  • Gaggia Expert
  • 151 Answers
What mean "still in descaling mode". Try to open the hot water knob ,put some water in watertank.When the water finish close the hot water knob fill watertank with fresh water and open knob again,when the water fiish the descaling is over.
Posted on May 20, 2015
    Top Expert:
  • Gaggia Master
  • 66,513 Answers
Possibly unplug from the outlet .
5 Suggested Answers
Anonymous
SOURCE: gaggia titanium is leaking water
Mine had the same problem. Take out the dreg drawer and brew unit. Then you will see a plastic cover roughly in the middle of the machine (behind where the brew unit was) that is held in place by two philips screws. Unscrew the screws and take out that small cover. It is probably filled with coffee grounds that prevent water from dripping out through a dripping hole. Clean out the grounds and you should be all set.
Gerwin Schalk Albany, NY
Posted on Aug 14, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Buttoms on Gaggia Titanium not working
Hold down the descale button for 5 seconds its the double ellipse, that should put it in a clean cycle. It is possible that it needs cleaning and it locked up because it was not getting cleaned.
Posted on Sep 17, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: my Gaggia Titanium machine says ventilate
Run about an ounce of hot water from the wand.
Posted on Nov 12, 2009
ifr500
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
btmachi
  • 81 Answers
SOURCE: my gaggia titanium reads"decalcify" what does it mean?
To cancel the message,press and hold the water button for 5 secs, until the message is clear. The machine is due for descaling to clean the boilers.
Posted on Mar 28, 2010
Why does my gaggia titanium say 'ventilate' 24 hours after decalcifying?
There is an air gap in system running the hot water clears it out.
Sep 04, 2014 | Gaggia Titanium Espresso Machine
I have a Gaggia Titanium, I did descaling, had difficulty during the process. It shows ventilate. I have tried priming, but it doesn't pump water through the nozzle
Hi.
Disconnect and re-apply power (unplug power cord). After that try doing rinse and descale procedure as from manual. You may need to keep adding water while performing the procedure.
See also: the ventilate error.
Regards.
Ginko
Apr 20, 2011 | Gaggia Titanium Espresso Machine
After descaling, cleaning the steam wand and checking everything, including opening the steam valve, etc the pump on the Gaggia Titanium coffee maker does not appear to be working. How is this fixed?
You may have a blockage, are you using correct descaler? Does it get warm, does the pump even come on? Many possibilities here. This is advanced mechanical troubleshooting, you must remove the rear panel and do diagnostics and troubleshooting or ship it to us, we are in LOS ANGELES, CA.
Mar 07, 2011 | Gaggia Titanium Espresso Machine
Our titanium gaggia machine is displaying decalcify, what do we need to do?
If you have a display that says "Decalicify machine" mdo this. To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. It must be large enough to catch all the water in the tank. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Sep 24, 2010 | Gaggia Titanium Espresso Machine
My gaggia titanium reads"decalcify" what does it mean?
Mar 23, 2010 | Gaggia Titanium Espresso Machine
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
Sep 10, 2009 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
395 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
