Question about Homelite Garden
Homelite Pro weed trimmer, model TLT254EBC. Where can I find a replacement carb?
Not knowing there was a carburetor kit I threw out the entire carburator.
  • Eugene Rounds May 20, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Any other numbers that can be referenced?
  • Anonymous May 20, 2015
    The SN number EUN3490234. There is another number AHCPS0254TA
Bill Boyd
    Top Expert:
  • Homelite Master
  • 53,816 Answers
Go to any mower shop that repairs homelite and get one
go on line to homelite select the page for replacement parts and order on line .
previous pages give a price between $12 -30$ us.
try e-bay for carby
Posted on May 20, 2015
4 Related Answers
ROB
  • 858 Answers
SOURCE: have homelite weed trimmer that won't start
recheck carb dighram is located properly! & that its sealed at the mounting of manifold to head!
Posted on Jul 24, 2009
Kerry Degrand
  • 112 Answers
SOURCE: gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Posted on Jul 25, 2009
Anonymous
  • 3 Answers
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Posted on Sep 08, 2010
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: I HAVE A HOMELITE GRASS TRIMMER MODLE UT21044A
Hi jackietwodog...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
NOTE: Before you disassemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank, and not idle properly.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 29, 2011
Carburetor needs kit
That particular saw came with one of four different carburetors. Luckily they were all Zamas and they all appear to use the same rebuild kit, the RB-69. The cross reference doesn't cover the S108J version but it should the same as the original S108.
Carburetor listed in IPL are CIQ-S32, CIQ-S61, C1Q-S61D and the C1Q-108J. To verify which carburetor you have the model number are imprinted on the carburetor body.
Nov 05, 2014 | Stihl Garden
22r carburator diagram
There is said diagram in every rebuild kit for the carburetor.Assuming you're going to rebuild it,that is.And if you're having problems with it,rebuild it.Any NAPA store will get the kit for you.
Apr 13, 2014 | Toyota Pickup Cars & Trucks
My RPM is not stable because my carburator is not clean...i want to clean it but i dont know how..will you please give me an instructions to clean my carburator?my car is honda vti 96 model. thank you
As i understand, all VTi´s had injected engines, but in case your particular model is carburated, my advice is: Take it to have it cleaned by a mechanic that knows carburetors. Have in mind that carburetors have a myriad of screws, jets and wires that might get lost or switched during reassembly. Furthermore, the jets, butterfly openings, floats and other devices require detailed, minute adjustments for proper functioning. All those adjustments are lost when disassembled for cleaning. Also, some rubber / plastic parts and seals will not withstand the acid bath, so a new kit must be included as well.
Jun 23, 2011 | 1996 Honda Civic
I need a 22R aisan carburator diagram so I can rebuild my carburator.
purchase the carburetor rebuild kit for your carburetor and it should have instructions in the box to aid you in rebuilding it . Remember , to do it correctly you must get an acid wash tank to submerge the entire carburetor body into before you install the new parts . And be sure to clean it thoroughly after you remove it from the acid dip tank .
Nov 18, 2010 | 1986 Toyota Pickup 4WD
My Briggs 10 HP Generator is outside and covered and wont start. It will run with gas sprayed directly in the carburator throat bit not on its own. I have just installed a carburator kit and a new spark...
Don't leave gas in the tank, or add additive to gas >>> you know that but the next reader might not know.
If you are able to get washer running by spraying WD-40 or some other accelerant directly into carburetor but engine will not continue running ... there are 3 suspects: 1) dirty air filter 2) the exhaust port is clogged with carbon, dirt, etc 3) the carburetor has given out or no gas is getting to carburetor
2) Check exhaust port >>> we finally broke the screen out with a screwdriver so it wouldn't bother us any more
3) Carburetor ... you have spark but the gas is either not getting to carburetor or carburetor is not letting gas in. Pull off rubber line going to carburetor and see if gas flows out. If gas gets to carburetor and all the conditions above are met, then the carburetor needs gum out or rebuilding or replacement
Oct 16, 2010 | Briggs & Stratton Briggs Stratton 6200...
Is there a rebuild manual for the carburator
the little Walbro carburetors or those like it are difficult to rebuild successfully but as to your question, you should repace the parts as you encounter them in the carburetor.
Jun 02, 2010 | Mantis 2-Cycle Tiller
Carburation Getting gas to the carburator but will not stay running without choke on
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 31, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I am having one Trimmer Model HLT16. The carburator unit is damaged, and want to replace. Where from I can get complete carburator unit to match the model. I want to get it from LA area of US. I am from...
Have your friend look in the Yellow Pages phonebook for a Lawnmower Repair and Parts store. Most carburetors can be rebuilt. A repair kit will cost less than a new carburetor. If you can't find what you're looking for let me know. Maybe I can find it here in Kentucky.
May 03, 2010 | Homelite Mighty Lite Lawn Trimmer
CARBURATOR KIT
Remove the carburetor slide from the throat of each carb. Now move the clip on the jet needle down one notch and put the carb back together. There is a notch on the side of the carb slide. When installing, it lines up with a pin inside the throat of the carb.
Apr 28, 2009 | 2002 kawasaki ZZR 400
Garden Logo
225 people viewed this question
Top Homelite Garden Experts
bryan st
Randy Schumann
Randy Schumann
colesmowers
Are you a Homelite Garden Expert? Answer questions, earn points and help others
