What can I do its shwing error which says ie
Its not spinning or washing anymore
  • Thomas Smithbrother May 19, 2015
    Hi LEONARD ONUNAKU, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    cods are brand and model specific. Make and Model please.
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
IE - Water level sensor error Water sensor fails to send signal for longer than 5 seconds. Press POWER button. No other buttons work:
· Check wiring harness
· Check pressure sensor switch
· Check circuit board
Posted on May 20, 2015
6ya staff
SOURCE:
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My Daewoo DWC-UD1212 washing machine does not spin; and shows IE whenever the light indicator is on Spin. What should I do?
not sure bout the IE error But I would check the clutch, the motor coupler, the door switch, and the belt if applicable?
Feb 28, 2015 | Daewoo Washing Machines
My LG WM2277HW washer always gets an IE error. To finish the wash, I change the setting to Speed Wash and punch Rinse Spin. Sometimes, I get lucky and the wash finishes. Most of the time, I get another...
Hi
Thanks for using FixYa. Error IE water inlet error which occurs when correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. To start with you can try to clean the filter if this wont help then you'll have to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | LG WM-2277HW Front Load Washer
Error message
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jul 11, 2010 | LG WM2016C
Error code ( IE ) on my samsung washing machine model wa13g7q1
1E - WATER PRESSURE SWITCH ERROR
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Gets to the spin cycle and does not spin and drain
What is error code?
Does unit spin?
Does unit drain?
Does unit fill on all water settings?
Ie set to hot, warm, and cold and see if fills.
Jul 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
