Cell Phones Logo
Question about Cell Phones
Are the Batteries for the Tracfone LG420G and LG440G interchangeable?
Both batteries are 3.7v; have the same physical dimensions; The LG420 has 900mAh The LG420 has 950mAh
Posted by Richard Baratta on
Steve
  • 3,290 Answers
If the same voltage, physical dimensions and technology (NiMh / NiCAD, etc.) they are interchangeable. A *new* 950 mAH rated battery will power the phone under identical usage a little longer than a *new* 900mAH rated battery. I choose the higher mAH rated batteries whenever possible and at comparable prices because of this - everyone ought to, too.
Posted on May 19, 2015
Please help. how do i unlock the sim lock code-1 for lg420g? the imei is 01212500220719003. my network carrier is smart gold.
Hi Angel, think I have the same problem...lg420. sorry don't have an answer...mine is at&t. Really hate going to at&t store, they are friendly, if they think you are there to buy something.
I will keep checking back to see if you received an answer.
Jul 20, 2015 • Cell Phones
Are the Batteries for the Tracfone LG420G and LG440G interchangeable? Both batteries are 3.7v; have the same physical dimensions; The LG420 has 900mAh The LG420 has 950mAh
It is not recomended to change battery . if any mistake happened it may burst or damage your phone because charging time, circuit range etc differ
May 19, 2015 • Cell Phones
1helpful
2answers
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
Can a car charger for the LG420G also be used for the LG440G? The terminal for the phone side seems to fit.
Typically, if any phone also uses a USB charger for using a laptop of desktop PC, then it's no problem as long as the charger adapter fits the phones. (USB ports are standardized at 5 VDC output, so anything of 6 VDC and less will work just fine. A lower voltage will take longer for your phone to charge. DO NOT GO OVER 6VDC for phones that accept a USB charger adapter from a PC.
Sms restriction 45
TracFone International Texting Revoked
  • Certain mobileicon1.png phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to an international number that says, "Check SMS Restrictions."
Read more : http://www.ehow.com/info_8634048_trac-phone-problems.html Did you upgrade from the 420G to 440G? Certain mobile phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and the Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to am international number that says, "Check SMS Restrictions"
Or your phone isn't capable of texting internationally.If it's supposed to then you need to call Tracfone customer service and tell them.
How to change the clock on tracfone lg440G
To change the time on a Tracfone LG440G, turn the phone "off", then turn it back "on". If that doesn't work, turn it "off", remove the battery, reinstall the battery, turn it "on". Time should display properly. No way to change the time manually.
4helpful
3answers
Where can I download a Users Manual or Guide for my new LG420G Tracfone?
You can download the user manual for this unit from this link, just click HERE.
Top Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Cell Phone Expert? Answer questions, earn points and help others
