Question about Dehumidifiers
We don't have a manual, it's a new unit but never been used. We can't figure out what all the control panel buttons mean. Help please.
It seems to run constantly, and we need to know how to set the humidity level, and get it to turn off when full.
Posted by Wendy Bransom on
J.D. Browning
  • 2,760 Answers
If its a newly mfg unit then yes the fans gonna run all the time , that's done to increase efficiency , if you hold down on arrows then you should be able to adjust the rooms humidity level, the default screen is the actual rooms humidity level , if you hold down mode button , this will cycle thru some timer modes that ind on the display
it should turn itself off when bucket is full , this even stops that fan from running most times
Posted on Jun 06, 2015
5 Related Answers
Anonymous
SOURCE: User Manual has no guidelines.
When you first turn on the unit it is set to 40% humidity which is the lowest the unit will accept. You can only move the up arrow from that point. The 63 you are seeing is the actual humidity. If you want 50% youo need to press up arrow till 50 is displayed. The manual for this unit is terrible. Just leave it as it is and it will attempt to bring it down to 40%. 30 to 50 is the recommended humidity range.
Posted on Jun 23, 2008
Michael Anderson
  • 172 Answers
SOURCE: no water in the bucket
You most likely have a freon leak, or the compressor is not running. When the machine first turns on you should be able to see if the compressor is running or if it is just the fan. If the compressor is not running it does have a start devise and a relay on it that can be replaced. If the compressor is bad, most units have a 5 year warranty on the compressor, so contact the manufacturer for warranty service. If the compressor is running you have a freon leak, and it would need to be found, repaired and the freon replaced. This is a large repair, estimated charge for a leak repair would be around $149.99 The reason is the long time it takes to find the leak, and all the parts needed. Drier, valve, freon, etc.. Good luck, and I hope it is only the relay. You can get those relitively inexpencively. 3 in 1 kits are also good for a hard to start compressor. They give the compressor a little more kick to start it. They are about $28.00 and easy to install once you are to the compressor. I hope this will FixYa.
Mike
Posted on Sep 30, 2008
Anonymous
SOURCE: Humidity buttons don't seem to work.
the control board is a very simple design and it is to signal and switch options like fan speed, power on/off, humidity up/down and sets the on/off run time. Like above the board does collect dust,but the true problem runs deeper.
My unit was stuck in run mode with the fan speed, humidity and run timmer non functioning. the unit worked and the power switch turned it on and off. The display said ON
I removed the front cover (two screws) and slight pressure on the side of the cover to remove it. This exposes the control board. The control board can be removed by removing the 6 screws on the board. the cable can then be removed by pulling out the multi-pin ribbon cable.
I diagnosed that only two of the 5 push button switched were functioning. There was also dust and mold on the board. This board is poorly protected from the moist air entering the unit and the constand moisture causes corrosion on the board, the switched seem to be the weak link.
By using a multi meter I noted that only the power switch and the humidity down button were making contact when pressed. Now it all came together. I could turn it on and off. and if you press the humidity down button to the lowers setting (ON) means run all the time.
I used a elecronic contact cleaner and sprayed it into each of the switches. I wiggled it around and blew it out with canned air. It took a few wiggles and blasts but all switched then made contact. I the board back on and tested all functions and it was like new. The contact cleaner should keep it protected for a while. The non functioning of the switches works both ways. They can stick on also. This would explain most of the other control problems. These switched are common and can be picked up at Radio Shack. On a do-it-yourself bananna scale it was a 2 for me, but I had the tools and the spray. I am not sure what sears gets for the PC control board,but this is the issue and if they were to address this the unit complaints would drop greatly.
Posted on Jan 12, 2009
Anonymous
SOURCE: The dehumidifier is running but very little water
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
Posted on May 09, 2009
Johh Coffey
  • 4 Answers
SOURCE: Stopped Running - Control Panel CH 01
All, I had this same problem as well. I called the LG Support Line and they told me the unit needed to be serviced. I went through the motions of getting the service providers and what have you, but I wasn't going to go through with it because the closes service provider was a 45 minute drive. I posted how disappointed I was because I had only had the unit for a year, but could not find my earlier post.
Anyay, I am glad I went through the motions, because a few days later LG called and told me they would be shipping me a refurbished replacement. Wow. That was a treat. They shipped me a refurbished unit and had me send the old one back. I did not have to pay a dime. The sent me the Fedex shipping label via email and I called Fedex and they came by and picked it up.
I cannot remember if I had registered the unit when I initially purchased it. Sometimes I won't do that because it seems only to serve as a license to sell me stuff. They took down all my contact information and sent me the unit so I don't know. I would simply encourage everyone with the CH 01 error code to give LG a call via the support number from their website at lgappliances.com. Good luck!
Posted on Sep 28, 2009
I got a new Whirlpool dehumidifyer (AD50GEUSX) I put the hose in and the green light on "continuous" and the water will not go through the hose. The machine stops when the bucket is full. Your...
Christianeta, first let me clarify one thing. The FixYa website you posted the problem on, is not the Whirlpool website, nor the Canadian Tire website.. And we don't sell appliances of any type. But, I can help you with your problem.
Despite it being a new unit, there may be some packing material clogging the inner tubing of the the hose connection. Or the hose you're using is to long (over 48") or is kinked or is not sloping down and straight to the floor drain. It relies on gravity to drain, so it will not drain up. When any of the aforementioned happens, water is diverted into the water collection bucket.
To clear any potential packing material or a clog from the inner hose connection tubing, please do the following:
Turn the unit OFF and Unplug it and disconnect the hose.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. It may take 10 to 15 minutes for water to start flowing. So, be patient.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helped you. Thanks for choosing FixYa.
Aug 24, 2011 | Whirlpool AD50USS Dehumidifier
I have a DANBY PREMIERE R410A dehumidifier. I have misplaced the manual. I want to have the unit run for a fixed period of time (not all the time). HELP!!!
On the control panel the 3rd button from the left is the timer button. If you press this button when the unit is running the number display on the left will start blinking- use the up/down arrows to set the time that you want the unit to run.
If you press the timer button when the unit is off it will run on and off for the designated time you set- eg if you set 1 then every 1 hour the machine will switch on and run for 1 hour.
(The left # will just blink once you have the time you want just leave it and eventually the normal humidity setting reading will show)
Oct 18, 2010 | Danby Dehumidifiers
My Comfort-Aire BHD-501-B is running. However, none of the control panel buttons work. I cannot turn it off with the on/off button. I cannot change the humidity set point using the up or down arrows. I...
I don't think it's a thermistor problem, as previous respondents have suggested. I have one of these units. The control panel has been nothing but trouble. The Power button works, but the Fan Speed button is stuck on High. The Humidity Up/Down buttons only work sporadically. Sometimes they work if I keep punching them. There doesn't seem to be any rhyme or reason as to when they work and when they don't. I think they're just cheap parts that have failed prematurely.
May 03, 2010 | Comfort-Aire HD-651 Dehumidifier
None of the control buttons work.
the only company, if the parts were available at all, that would have them, would be dey distributing in duluth mn, phone 218-723-1626. give them the part number and they'll look it up for you. All of my available sources tell me the part is no longer available, so you may have to replace the unit if dey can't help you. try purchasing a kenmore, they seem to work fairly well.
Jul 02, 2009 | Goldstar DH504EL Dehumidifier
Danby DDR401. Can't get it to remove moisture from the air.
Hi Fred, let me see if I can assist you. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
May 27, 2009 | Danby DDR401 Dehumidifier
Jul 22, 2008 | LG Dehumidifiers
Control panel
Just found an owners manual for the sunbeam version - p1 = defrosting. It will restart after it defrosts.
http://www.sunbeammajorappliances.com/pdf/Dehumidifiers%20manual%2020070122.pdf
Mar 29, 2008 | Kenmore 53701 Dehumidifier
Feb 03, 2008 | Kenmore 54701 Dehumidifier
Humidity Control
Sounds like the button may be broken. However, it could be a loose wire. Take the front off and see if any of the wires connecting the control panel and the unit are loose or disconnected.
If there is a ribbon cable connecting the control panel, see if any of the contacts are exposed when you disconnect it. If they are, you may be able to use a pencil eraser to clean them off. A service man from Sears did this on the control panel for my ceramic-top stove. He said if that didn't work then I would have to buy new control panels, which were almost the cost of a new stove!
Sep 09, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
205 people viewed this question
Top Dehumidifiers Experts
Marvin
Marvin
STEVE SPAM REMOVER
ray gallant
Are you a Dehumidifier Expert? Answer questions, earn points and help others
