Question about Saturn 2008 VUE Red Line
How much Freon dose my 3.6 hold - Saturn 2008 VUE Red Line
Posted by sonny knapp on
D. E. Hev
    Genius:
  • Saturn Master
  • 1,187 Answers
Saturn 2008 VUE freon charge Bing Videos
http://www.saturn.com/content/dam/saturn/northamerica/usa/nscwebsite/en/Home/Owners/Owner_Resources/Manuals/en/us/2008/vue/2008-saturn-vue-owners-manual.pdf
Posted on May 19, 2015
  • D. E. Hev May 19, 2015
    5-104 in owners manual
Cimbali m29 selectron 2gr espresso machine. power outage from electrical source. when power was restored, tank heats up and comes to pressure, however no water will dispense from heads...
* You will need to program groups again.
* I'm surprised I did not record and upload a programing video *sigh*
Oh well, somebody did it already:(check at 3:57 on the following vid)
https://www.youtube.com/watch?v=0-3SbS-PU4Y
* Set up each shot with a filled portafilter (for the appropriate dose setting. Single for single, double for double, etc.)
* Press and hold "Stop" button till it light (and/or beeps). Release stop button
* press and HOLD the appropriate dose button (within 5 seconds or it cancels out)
* Watch the coffee dose as it pours out into cup or a shot glass (for accuracy)
* Release the dose button just before it hits the desired amount. You may have to do this several times to practice.
* Continue with setting the dose on the other settings (long, double, etc.)
* Note; you can set the "least used group" as in a 3 or 4 group head machine with specialty doses. Like a triple if you have the proper portafilter for this shot. Or an "American" long shot (though I don't recommend running 6-8 oz of water through a single coffee dose. Though I have found some shops using drip coffee through a triple basket and very long dose to fill mugs. They didn't want to get a regular 12 cup brewer.)
* There are other dosing tricks like copy over to other groups. But I've found that setting each group and dose is good practice. (and I have to do it several times a day as a Espresso Tech.)
Aloha, ukeboy57
Aug 09, 2017 | La Cimbali Coffee Makers & Espresso...
Hi just wondering how u caliberate a esspresso shot on a La Cimbali M23 machine. all heads only run for half of a second.
* You will need to program dosing on each group head.
Aloha, ukeboy57
Jul 31, 2016 | La Cimbali Coffee Makers & Espresso...
How much freon does the system hold 99 grand am 4 cly.
Hi, majority of car A/C systems hold about 3 pounds of R134a refrigerant. Mike
Jun 14, 2011 | 1999 Pontiac Grand Am GT
Why does the playstion 3 dose not work on standard tv
Have you tried holding down the power button for 5 seconds to revert back to standard definition?
Jul 23, 2010 | Sony Playstation 3 (PS3) Console
Massage said low ref ac off what dose that mean thanks
that means low refrigerant available and the low pressure switch is preventing the compressor from damaging itself. You will need freon added to the system which in not uncommon since mobile a/c systems normally leak a small amount each year and eventually need topped off to work properly. Either buy some freon from a parts store or find an independant repair shop that will agree to just add the freon necessay to make the system work again. Freon necessary on most systems ranges from 1 to 2 pounds and freon bought in bulk by all shops costs $3 a pound and labor to do this is about a half hour so look at their labor rate and add a reasonable profit for the freon and this is what it should cost. If this helps please reply cause that helps me and good luck
Apr 29, 2010 | 1998 Cadillac DeVille
My air conditioning dose not get cold enought
This means you need to add more freon, you can take it in to get added or just go to your nearest auto shop and buy some with a connector and just turn your car on with your air conditioner on high, and connect the line to your can then to the low side of the air conditioner lines and hold the can up right so you let the gasses in, not liquid. when can is empty remove from low side and be careful disconnecting from can because freon is very nasty stuff and may still have a little in the can. and repeat until necessary.
Apr 23, 2010 | 2000 Jeep Grand Cherokee
I have a 1999 chevrolet express van, the ac dose not work. i turn the ac on and the clutch dose not engage on the compresser.what could be the problem? i have checked the fuse and the relay. they seem to...
Bruce did you check the freon. if the pressure is not enough the ac clutch will not engage. If it is the freon you may want to use a leak detector from your local autoparts store before wasting freon.
Jul 07, 2009 | 1999 Chevrolet Express
A/c freon is not circulating, what is the problem.
well how do know that? if you have gauge dose it show any thing is there any Freon? is the compressor on? if not that is your main culprit. are there filters on the freon lines? there is a metering piston at evaporator on the High side. go to the Schrader valve see if any freon come out.
Jul 04, 2009 | Heating & Cooling
Saturn 2008 VUE Red Line Logo
178 people viewed this question
Top Saturn GPS Experts
Marvin
Marvin
Tom Chichester
Are you a Saturn GPS Expert? Answer questions, earn points and help others
