Question about Stoves Dishwashers
Dishwasher is tripping RCD, can it be repaired?
I have a Stoves integrated slimline dishwasher and it has started tripping the RCD. First of all it was working and once it had filled with water and heated up would trip. Now there is water in the bottom of the dishwasher and everytime I turn the dishwasher it trip immediately; before a program has even been selected. Can it be fixed or should I just buy a new dishwasher?
Posted by Rachel Westwood on
Bill Boyd
    Top Expert:
  • Stoves Master
  • 53,816 Answers
Not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
Posted on May 20, 2015
5 Related Answers
Anonymous
  • 185 Answers
SOURCE: trip switch
is the dishwasher on its own circut breaker if so whats the size
Posted on Mar 28, 2008
Anonymous
SOURCE: Tripping out RCD
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Posted on May 22, 2008
Anonymous
SOURCE: Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Posted on Jan 09, 2009
Anonymous
  • 56 Answers
SOURCE: Fuse box keeps tripping out everytime I put on my dishwasher. New problem.
the dishwasher element or pump has grounded,disconnect them seperate to iliminate which one,follow safety guidelines when operating on electrics hope this helps
Posted on May 28, 2009
Anonymous
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Posted on Sep 04, 2009
Hi, S450DW when you set a program it doesn't start on any program.
Is this a Stoves S450DW Fully Integrated Slimline Dishwasher?
Find manuals here
https://www.stoves.co.uk/find-manuals/
I have a Bosch Classixx slimline dishwasher. I completes most of the cylcle but trips out the electricsnear the end of the cycle - probably the drying cycle - any ideas Garry
Hello Garry,
I suspect the element in the water heater is either burning out or shorting to earth. If it's burning out, the increased resistance will cause an overload and trip the breaker or blow the fuse for that circuit. If it's shorting to earth, it may trip both the breaker and the RCD in your fuse box / consumer unit.
Next time it happens, check whether the RCD switch (assuming you have one) is in the 'OFF' position. Most breaker boxes will be fitted with an RCD which protects many, or all, of the individual circuits. It's easily identified by the presence of a 'TEST' button.
That's only going to be a clue to the likely cause of the fault though. You really need to do some testing of the element with an ammeter and/or multi-meter, if you have one. I can provide instructions for testing if you have the equipment and inclination.
Unfortunately, if it is the water heater, the cost of a replacement is about £100 for the part alone, for the SGS43C12. Water heaters for most other Bosch models are roughly the same price and some of the older models can be £130+. If you need to get someone in to fit it, you could be looking at a total bill of between £150-200. Considering the age of the SGS43C12 / Classixx, it may be time to consider replacing the dishwasher.
Obviously, I'm assuming it's the water heater as this is the most likely cause, but there are other possible faults. If you need any instructions on testing, etc, please confirm the correct model number as the SGS43C12 isn't a slimline model.
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Thanks.
Oct 21, 2008 • Dishwashers
1helpful
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
DI 67 Diswasher trips RCD fusebox
either the element is faulty or poss the electrical filter.
Rcd tripping
Well done ! Thanks for the information.
Dishwashers Logo
Top Stoves Dishwashers Experts
ADMIN Canada
ADMIN Canada
Fred
Fred
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
