IBM TravelStar 40GN 40 GB Hard Drive Logo
Question about IBM TravelStar 40GN 40 GB Hard Drive
IBM Travelstar hard drive
I have a IBM Travelstar hard drive. I lost the disk to install it into my computer before I can put anything in it...is there a place online where I can download it??
Posted by danikaee on
  • Chris
    Chris May 11, 2010
    Hi, Not sure what disk you're looking for as no additional driver are required to install normal harddrives. Are you looking for a windows disk? Chris
Anonymous
    President:
  • 1,179 Answers
The IBM webite will have the software located under the support link. You will need to lookup your specific model # and then the files will appear. Download and install those that you need. Hope this helps.
Posted on Jul 11, 2009
1helpful
Hi, I have one IBM Travelstar USB 2.0 external hard, suddenly now it is not deducting and the light which is there in USB device, some time it is green and red alternatively.. Pls help to resolve this...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Computer not picking up IBM Travelstar hard drive
The warranty on any '20GB' disk-drive ended _years_ ago.
It is time to "retire" that disk-drive -- take a hammer to it, so that any data files on it will _never_ be able to accessed by the F.B.I.,
and buy a new disk-drive.
1helpful
2answers
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Drive not displayed in my computer
go to the control panel , then open the administrative tool then open the computer management then disk management check the status of hard drive there
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
My computer crashed
REmove the hard drive from computer, place it on a caddy and connect it to another computer, try to acces it. If accesible, recover all the data you can if not, download a recovery program from the internet.
Dell laptop with no cdrom and travelstar HDD
In this case you would have to...
1) preformat the drive
2) make it bootable in DOS
3) copy the CD contents to the drive
4) boot the target computer with the drive and run WINNT.EXE in the I386 directory to start the install.
*OR*
2) copy the CD contents to the drive.
3) put the drive in the target computer and boot it from a DOS bootable floppy.
4) run WINNT.EXE in the I386 directory to start the install.
Onlly 2 GB shown on a 10 GB Drive
try to check whether the disk jumper is correctly placed then use another os to format the hard disk i.e os win xp
1helpful
3answers
Lost Master Harddrive Password
First chek in BIOS if exsist CHANGE HDD PASSWORD if not use download somwhere HIREN BOOT CD v8.2.Let me know if u got help;)
Top IBM Computers & Internet Experts
tonyy168
tonyy168
Level 1 Expert
David Shaub
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
