Refrigerators Logo
d
david allen reynolds Posted on May 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking water from inside.water on bottom of inside.not evaperating out of drain pan in back.
Rhonda Webster
Level 3:
  • Master 978 Answers
  • Posted on May 18, 2015
Rhonda Webster
Master
Level 3:
Answers
978
Questions
Helped
446837
Points
2917
David: According to PopularMechanics.com: "Usually, it's because the icemaker line has sprung a leak. People don't realize that there's a shutoff valve. Typically, it's under the sink; if not, look in the basement, beneath the fridge." However, David, for me personally, I found this to be true: "The drain tube is blocked. Unplug the refrigerator and locate the drain plug near the back or bottom of the main compartment. Use a turkey baster to force a 50/50 solution of bleach and warm water into the tube. Repeat a couple of times, then remove and clean the drain pan located underneath the refrigerator."
My Maytag MZD2766GES is leaking water to the bottom of my freezer, which, when it get alot starts leaking all over the floor. where is this coming from?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
tip
What is wrong when your side by side refrig. leaks from inside the freezer
Gene
on Aug 04, 2011 • Refrigerators
1helpful
Sometimes I see water under it. And the pan is always dry. Is there a clog somewhere in the line?
Gene
2answers
My refridgerator leaks sometimes on the freezer side. i think it leaks when it goes into defrost mode. i turned the freezer off for a couple days to thaw out and then cleaned it out. after i turned it back...
Hello Fred,
I dont know if it is top freezer or side by side,so here are tips i wrote about each type leaking
TOP MOUNT FREEZER
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
SIDE BY SIDE
Gene
1helpful
Water is collected at bottom of basket in freezer. What can I do ?
Gene
2helpful
Model52552100 side by side kenmore. What cause ice build up on bottom of freezer?
Gene
1helpful
Magic chef model number CSB2323AR seems to be a defrost problem. Water accumulates at bottom of freezer then ices up. Is there a drain pan on this model?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the lower right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
Gene
My model number 2811 has ice build up on the right hand side of the freezer. the service manuals indicate i need to pull the "cal rod heater down to make contact with the evaporator assembly and silicone...
Diagrams here : http://www.searspartsdirect.com/partsdirect/part-model/Sub-zero-Parts/Refrigerator-Parts/Model-2811/3054/0161000?searchedModel=2811&blt=05
These are the best I can Do with the Diagrams but I can explane what is going on, and possible soloutions.
Your defrost drain is mostlikeley frozen. This is located on the right hand side, just inside the metal cover. When you remove the meteal cover (((evaperator cover or water pan))) you will see the hole on the right.
Since this is cloged then the water stays in the cover or pan and freezes after the defost cycle.
after you remove the cover you will see the evaperator (( aluminum tubing with fins))) and the heater ((( Black Rod )))
When your machine gose into defrost about every 8 hrs, this heater melts the ice off the evaperator((( Hence Frost Free ))) and the water goest into the (((( evaperator cover or pan ))) and flows to the defrost drain hole to a pan under the machine.
They make a after market heater for the drain... it is a pain to install.
First I would try to defrost the drain by poring war water down it and verifying it goes into the pan at the bottome of the machine.
When your done you will need to silicone around the (((cover / pan))) where it covers the defrost drain hole.
Good Luck
Don
Mr Fix it
2answers
Water pooling & freezing in the bottom of a kenmore model 795.75252400 freezer compartment
The problem is the water drain tube in the freezer is clogged. As the evaperator goes into deicing mode the water from the evaperator is not going down the drain tube. Instead it's over flowing those two air ducts to the refridgerator and causing your water problem. But it's not as simple as simply clearing the clogged drain tube. You need to install a heating element inside the drain tube to keep it from freezing during the deiceing process.
1helpful
GE TCS18PADBLBS Freezer
if the drain line is frozen or clogged then you have to remove the back freezer panel and with a hair dryer at the bttom of the evaperator coil thaw the ice that is built up in the evaperator pan ouce you have it thawed you can pour water into the evaperator pan and it will run into the drainpan if you pour water into the pan and it does not run into the pan keep thawing
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
