SOURCE: transfer music from limewire to mp3 player
heres what i did:
when u plug in your mp3 player, s screen should pop up click view files. when you download songs in limewire they should save in your documents so you pull your documents up and their should be a limewire file. go to the saved one. then transfer the songs saved to your mp3 player and it should work! worked for me :)
SOURCE: cant transfer limewire music from my computer to my mp3
Greetings!
Once you insert the mp3 player, the computer automatically detect the device, were you can see the folder inside of your mp3, create a folder from file, new, folder.
Now open the folder where the music was downloaded usually you can see that file at my document, save/complited folder, select all the file, copy
Open the new folder (which you created) in the mp3 then paste the songs that was downloaded.
To play the music in the mp3 player, just find the folder you created.
Thanks
SOURCE: album art does not transfer with music on my sandisk mp3 player
Go to the sytem Settings menu and go to this option:
Display Art in Lists
Enabling this feature displays a small image of the song album cover, audiobook
cover, and photos when scrolling through list of these items.
1. Scroll down to Display Art in Lists and select it.
2. Use thumbwheel to switch between On (enable) and Off (disable).
If changing this option to enable fials to resolve the issue, the solution is a bit painful: You will have to manually add the artwork to each single song within an album in Windows Media Player 11, delete the song that is missing the artwork off your sansa, and re-add the songs again after you are done manually ediitng the artwork.
Manually add album art (WMP 11)
1. Run WMP.
2. Click Library on the top bar.
3. Select and right-click the file(s) you wish to update and select Advanced Tag Editor.
4. Click the Picture tab, then click Add.
5. Navigate to the image you wish to use for album art then click Open.
6. Click Apply then OK.
SOURCE: i dont know how to transfer music to my philips mp3 player
I have a phillips go gear. If you have the songs in mp3, simply plug in your go gear using the usb cable provided, a screen will apear confirming that your go gear has been recognised asking you what you want to do click on open folder option.
Now you just need to drag your mp3 into that folder and there you go, music transfered
SOURCE: how do i transfer music from frostwire to my coby mp3 player
i dont hav windows media player 11.....is der neother way to copy d songs to my coby player....................
Step1. Download and install the DRM removal program - Daniusoft DRM Converter, the main interface is shown as below:
Step 2: Import AA files to the program.
Load AA files by clicking 'Add Video' button on upper left of
Daniusoft DRM Converter interface - choose file type as '*.aa' to add
files into the software.
Step 3: Set output format.
Choose "MP3 (MPEG Layer-3)" on the output format window, and select the
output folder to save the file to after it has been converted.
Additionally, if you hope for higher output quality, Daniusoft DRM
Converter allows you to set "Bit Rate, Sample Rate, Encoder, Channel "
for your tracks via "Setting" option.
Step 4: After finishing the three steps above, click
"Start" button, A progress bar will show the status of the conversion.
When the conversion is complete, the file is in opened format MP3..
Now you can own the AA sound tracks forever and you can feel free to
enjoy your Audible Audiobooks on such as Sony walkman, Zune(HD),
PSP(go), Creative Zen, Sansa Fuze, Android phone(Nexus one,
Droid(X/2)), HTC Phone(HTC EVO/Desire/HD2/HD7) .
Overdrive audio wma to mp3 ' wma to iTunes ' iTunes to Windows media player ' remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes ' remove drm from nokia music store ' m4v to droid ' iTunes to galaxy s tab ' sync iTunes to walkman
Step 1: Load DRM M4P files
Click "Add" to load DRM AAC files, you are allowed to import all
supported format music files:M4P,AAC, M4B, M4A, WMA, WAV, MP3, OGG, MKA,
AA, AAX, etc.
Step 2: Setting output formats
Click "drop-download" list at the bottom to select output format for
your M4P files. You may customize the output settings for AAC files.
Choose an output format from "Convert to". Click the "Settings" button
for detailed settings of "Bit Rate, Sample Rate, Encoder, Channel "to
make your output with high quality.
Step 3: Convert DRM M4P to MP3
Once you've finished all the settings, click "Start" button to
beginning your conversion. After conversion, you can click the "Find
Target" button to open the output folder and find the converted files.
Note: You can drag and drop all your music files to M4P to MP3 converter at a time, then do something else till it is finished.
Now you can own the music forever and play it on your mp3 players
such as Sony walkman, Zune(HD), PSP(go), Creative Zen, Sansa Fuze,
Android phone(Nexus one, Droid(X/2)), HTC Phone(HTC EVO/Desire/HD2/HD7)
as your will.
Turn on your computer. Connect your Samsung MP3 player to your PC via the USB cord. Power on your Samsung MP3 Player.
Click on "Open folder to view files" when it pops up or click on my computer and select the Samsung "drive."
Transfer music. A folder will appear containing all music files on your Samsung Player. Click and drag any music files from your computer to this folder to add them to your MP3 player.
Wait until the transfer is finished to disconnect your Samsung MP3 Player.
