Question about Measuring Tools & Sensors
Is there any way to change the battery on a Trumeter 5505E measuring whee
Posted by Bev Johnson on
John Sheridan
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
5505E MEASUREMETER BATTERY CHANGE (3V CR-2032)
REMOVE WHEEL AND SHAFT BY GENTLY PULLING AXLE OUT OF UNIT.
DRILL OUT 7 PLASTIC HEADS WITH 3/16 DRILL BIT. (ABOUT 1\8 DEPTH)
SPLIT TWO SIDES OF CASE AND REMOVE HANDLE.
SLIDE OUT CLEAR PLASTIC CONTROL UNIT. PUSH DOWN ON BUTTONS AS YOU REMOVE SO AS NOT TO DAMAGE THEM.
PUSH DOWN SLIGHTLY TOWARD THE CASE ON LOCK TABS WHILE GENTLY PULLING CASE APART. START ON ONE END AND WORK YOUR WAY TO OTHER END. KEEP GASKET INTACT. OPEN CASE.
THERE IS A "Y" SHAPED RETAINER HOLDING IN THE BATTERY. WITH NEEDLE NOSE PLIERS, CAREFULLY SLIGHTLY SQUEEZE THE BOTTOM OF THE "Y" AND PULL UP GENTLY. YOU CAN NOW REMOVE THE BATTERY AND INSTALL THE NEW ONE. PUSH RETAINER DOWN TO LOCK BACK IN.
MAKE SURE GASKET IS IN PLACE AND PUT CASE BACK TOGETHER, MAKING SURE WHEEL ADAPTER IS IN PROPER PLACE. TURN ON AND TEST CONTROL UNIT AND TURN WHEEL ADAPTER TO MAKE SURE UNIT IS WORKING PROPERLY.
SLIDE CONTROL UNIT BACK IN BEING CAREFUL OF THE BUTTONS. RE-ASSEMBLE HANDLE AND PUT THE TWO SIDES OF THE CASE TOGETHER. I USED THREE PIECES OF ELECTRICAL TAPE TO HOLD CASE TOGETHER. ONE ON THE TOP BETWEEN THE TWO HOLES, ONE ON THE BOTTOM JUST ABOVE THE DISPLAY, AND ONE IN THE MIDDLE.
PUT THE PLASTIC PIECE IN THE HOLE AND LINE UP. MAKE SURE BOTH O-RINGS ARE ON THE AXLE SHAFT. GENTLY INSERT AXLE ALL THE WAY IN WHILE ROTATING IF NECESSARY.
I WAS SO HAPPY I HAD IT ALL BACK TOGETHER AND WORKING, I HADN'T TAKEN ANY PICTURES AND I DIDN'T FEEL LIKE TAKING IT ALL APART AGAIN. MIGHT ADD PICTURES LATER IF NEEDED. I HAD BEEN LOOKING FOR YEARS ON HOW TO CHANGE THE BATTERY, AND I FINALLY MADE UP MY MIND THAT I WAS GOING TO DO IT.
JMS 10-20-2020
Posted on Oct 21, 2020
Looking for reset button oN TDX SD power wheel chair
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
Jun 14, 2015 | Drive Health & Beauty
How do I change the battery in a Trumeter measuring wheel 5505E.
JMS 10-20-2020
May 17, 2015 | Cars & Trucks
Kodak easyshare Z5010
Perhaps you just need a new battery. or the camera is defect.
Measure the voltage on the battery with a multi meter. It should give a little more that what is printed on the battery. so when it says 3,7 V on the battery you should measure 3,8 or 3,9. If not, even 3,7 outside the camera is not enough, then you need another battery.
Mar 08, 2015 | Kodak EasyShare Cameras
Instruction book for 5505e
I will send the manual to you by email, if you need
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Sanyo Office Equipment & Supplies
How do i change battery on trumeter 5505e
The device is not meant to have the battery changed (?!).
However, I am going to drill out the holes where the screws would go and try and change them myself. It doesn't not make 'consumer' sense to me to have this unit without being able to change the battery. It has a 5 year battery life but I only need this unit once in a while so in 5 years I may only use it once or twice.
Jun 07, 2013 | Cameras
Whee to buy battery cable ends and how to repair them
You can get replacement ends at any parts store. To install them, disconnect the cables from the battery and cut the original end off. Strip back about half an inch of insulation and put the end under the ******** the new end and tighten the strap. Make sure you mark the wires so you know which is which and put back all attached wires. When disconnecting a battery always remove the (-) first. When putting them back on, attach (+) first. That lessens the possibility of shorting anything out. Never allow anything metal to touch both terminals on the battery at the same time
Jul 19, 2011 | 1997 Ford Escort
''Firmware has detected cmos battery failure''
CMOS battery in the motherboard much measured .3 volt which is a Lithium coin cell battery.check whether the battery gives the correct measurement (recomend to use branded battery like from sony).
if the measurement is correct then reset your BIOS setting by removing all the jumper in the motherboard for about 60 secs.and place it again and start your pc;set yr BIOS to default setting,
let me know if it comes handy to you
Dec 04, 2009 | Intel Computers & Internet
99 Harley FLHTCU EFI, engine occasionally dies, on a restart can't hear fuel system pressurize. Cranks over good. Fuel Filter? Fuel Pump? Battery? (battery is 8 yeaars old) Thanks
Sometimes there is adaquate pressure and we don't hear the pump, but it does pump while crank and running. A couple of things here, one is the fuel filter, etc. and battery. You did not say how many miles are on the bie, somethings like the fuel filter are usually replaced based on mileage; while depending whee you are 3 years on a battery is about all you can expect.
The reasons why the bike dies can be many, especially at low RPM or idle. Check your air filter, replace if needed. Change your plugs if they are questionable. Change your fuel filter if you have 40K miles on the bike. Unfortunately you could have a range of sensors that are "tired" or about to go bad if the problem persist. The easiest thing to do is take to your dealer if after changing plugs, fuel filter, and air cleaner doesn't help. The dealer will hace the specialty tools to test the sensors and other components that may be in question. Usually they can determine what needs to be done in less than an hour.
Hope this helps.
JP
Oct 31, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Measuring Tools & Sensors Logo
579 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
