Question about Pride Jazzy 1103 Ultra Standard Power Chair
What are the trouble codes on a jazzy 7 power wheelchair
Posted by RAY GILPIN SR on
Lawrence Oravetz
  • Pride Master
  • 10,548 Answers
Http://www.manualslib.com/manual/134640/Pride-Mobility-Jazzy-Select-7.html . This is the owner's manual. It describes the trouble codes. You can download it to refer to it again.
Posted on Jun 18, 2015
3 Related Answers
Neil Wood
  • 177 Answers
SOURCE: Jazzy 1113 ATS Indoor Power Wheelchair: the battery is fully charged but it wont move does...
Hi. Your machine probably has a fault, but I very much doubt that it needs reprogramming.
Are the free-wheel levers in the correct place? Is the machine displaying any fault codes, e.g. flashing LED's and what is the pattern or number of flashes between pauses?
Good luck. Neil.
Posted on Jun 01, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: replaced battery in jazzy 600
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Posted on Oct 29, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: Pride Jazzy 1121 power wheelchair has leaked oil
There's not too much you can do about the gearbox leaking oil. The gearbox will usually leak at the top gasket or seals. I suppose you could try to re-torque the bolts holding the top gearbox flange, but the other seals are usually leak due to age or overheating. If you pull it apart to re-torque the bolts, you might as well replace it along with the motor and brake. The gearbox grease stains are hard if not impossible to remove from carpeting and flooring.
If the motor drags you could have a bad brake which indicates you should replace the entire assembly. If the chair veers to the right you might have one motor spinning faster than the other due to age or damage. You can go into the programming menu with a hand held programmer and adjust the steering correct to compensate for the motor difference.
The bottom line is that you are due to replace at least one brake/motor/gearbox very soon. I usually replace them as a pair since the other side will also need replacement soon.
The motor/brake/gearbox assembly will run you about $700 for each side. Labor cost will be about 1 to 1.5 hour per side.
This is an older model Jazzy which was very sturdy, reliable and popular. You should evaluate the condition of the other components when deciding how much to spend on the repair. Replacement for a comparable chair has gone up considerably and I personally don't think the motor quality is as good. Hope this helps.
Posted on Jan 09, 2011
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
I replaced batteries in my jazy power chair, and the control light flashes 9 times.
James,
the flash code for some of the Jazzy's say that your brake solenoid wiring has a problem, check your connections to both sides of the chair. Strege Mobility
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Nov 19, 2015 | Select Jazzy Used Electric Wheelchair
Reset code on jazzy
the code that is given by the Joystick is indicating where to look for your problem , once the the correct repair is completed the code should disappear.
Jul 08, 2014 | Select Jazzy Used Electric Wheelchair
I NEED THE CODES
Go to Pride Mobility website/ http://www.pridemobility.com/jazzy/
and get manual for Jazzy 1113 it is found on page 31 but manual for jazzy113ats doesnt have codes. Good luck.
May 12, 2014 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 6 flashes 7 times.
this is a problem with the Joystick or a connection to the joystick. Check the wiring first. It has been my experience that the controller may also have a hand in this code. Have a Qualified tech check it out. Strege Mobility
Apr 19, 2014 | Select Jazzy Used Electric Wheelchair
Light flashes 7 times
7 Flashes indicates a joystick trip. Turn off your chair, ensure the joystick is in center position without anything touching it and turn on chair. This should clear the 7 flash code.
This problem is quite common amongst power chair users. It typically occurs when something is pressing against the joystick as you are turning the chair on.
Feb 14, 2014 | Select Jazzy Used Electric Wheelchair
Y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
Jun 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy Power select 7
Put the chair in free wheel mode and then back again and then turn the chair off then on again. Sometimes the chair will get out of gear just a littel.
Oct 07, 2009 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
497 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
