First you have to check the line of pipe under the sink if its clooged.
just pull it from the sink to plastic tank and see if the pump gets out the water . if it works you have to clean the sink pipe . normally the pump has a non return valve (rubber flap )for the dirty water of dishwasher . if the pump cant drain the water from dishwasher propably the motor winged it does not work so you have to replace the drain motor . of course you have to clean all the filters inside the dishwasher. but from the description propably you have clogged pipe drain under the sink . you have to check drainage faucet if its clean otherwise all the water of sink goes back to dishwasher even a little quantiy and smells dirty.
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Testimonial: "I think the hose was the problem. It was not looped high enough to keep water from running back into the dishwasher. I'll see in a day or two if that was the problem. Thanks for your help."
Probably from decomposing food scraps left in the dish washer
use a quality dish washer cleaner
make it a principle to rinse off all dishes before placing in the dish washer.
Testimonial: "I always rinse dishes before putting them in the dishwasher, so that shouldn't be the problem. Thanks anyway."
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Hi
The smell usually comes
when the unit is unable to drain water completely, you can run your dishwasher at
its hottest temperature setting with 2 cups of vinegar inside the unit. After
this take off the lower front panel and clean the drain pump assembly completely, also clean the
drain hose, the smell should disappear after doing all
this. Hope this helps...please post back for further assistance.
Daniel
