Question about HP Compaq Presario V2000 Notebook
Not able to pull task manager
i have a HP Compaq Presario V2000 PC Notebook,
i am trying to check whats the processs running but the task manger option is not highlighted , i tried to press the ctrl+alt+del
but got error that your system admintrater has disabled this option,
while i am the administrater of the computer
  • Anonymous Nov 15, 2007
    thanks > let me try that , if it works will rate you ( by the way i always log into my computer as an administrater
  • Anonymous Nov 21, 2007
    Hi Guys ,
    Actually i got the Solution myself,,,,,,, the reason was a Virus or Malware
    ............... IF ANYBODU ELSE HAVE THE SAME PROBLEM THEN LET ME KNOW
    This virus willm disable your taskmanager,, regedit,,, and hidden files..........
Anonymous
    Problem Solver:
  • 16 Answers
Try to check your drive if you have "autorun" on the context menu.your malware came from on your thumb drive.you can erase it by booting on safe mode.then check your msconfig by running on it.on run type msconfig. then unchecked unfamiliar program running, sometimes it hides in system32.sometimes exiplorer,autorun.inf those kind of scripts running while booting normal mode.go to command line then make your directory on c:\ then type the following command-dir /ah to view the hidden file on your drive c:\ then attrib those hidden file.then erase it then reboot to normal mode.then if you've got same problem try to create new user on windows xp.
Posted on Nov 26, 2007
Anonymous
  • 22 Answers
It sounds like you may have an exploit on your system! If you restart in safe mode and log on as "administrator" (not your user, the machine administrator). To boot into safe mode, immidately after your system displays the startup messages, press F8 TWICE, scroll up to safe mode, and press enter TWICE. You should be able to go to the run command and enter "taskmgr" (without the quotes) or ctl-alt-del. You might need to do a little footwork to see if you have been exploited or (hopefully) just messed up your access accidentally.
Posted on Nov 14, 2007
Drivers for windows 7 for presario V2000
Compaq Presario V2000 Notebook PC has only drivers available for windows XP and 2000. HP has no driver download for Windows 7 for this model.
Please click here for reference
Regards
Riztech
I want audio driver for compaq presario v2000. i tried in hp site but it is not suitable
Compaq Presario V2000 CTO Notebook PC » Compaq Presario V2000T CTO Notebook PC » Compaq Presario V2000Z CTO Notebook PC
please select the correct one from the hp site and uninstall audio driver which one you installed earlier then try to install ..... i think you did not select proper one like above ....
Problems booting up--no access to toolbars, etc. on XP
To resolve this issue, simple trick is, when it stands at the wallpaper without Start menu and Task bar, Press Alt + Ctrl + Del keys
Then select TaskManager.
In the Task manager, select Process Tab.
Under that select Windows Explorer process and select End
Again click on File menu in the same Window and select New Task.
Type Explorer.exe in the blank and click okay--OK
That should bring the complete screen.
Modem driver
Hi Mofya,
HINT: your presario may not really be a V2000. My fiance's V2000 is actually a V2402AU. Try searching for the drivers for that model instead.
Modem and media card not recognized on HP Presario V2000, AMD, XP Prof, Vers. 2002 SP2
alll the drivers can be downlaoded from the compaqs site . u need to enter the seril number of machine . if that devices are shown in device manger with an yellow qn mark .then that devices will work if proper drivers are laoded . give me ur computer serial no . i will send the link to that files
Not able to open task manager
restart in safe mode (administrator) and try it again
2answers
Sound
Hi, 1st check the sound card drivers in Device manager if Sound card is not installed then installed it 1st then try for Music . IF sound card drivers is all ready present the reinstall it but 1st do 1 thing on ur Task bar u will get Icon of Speaker u need to right click on that icon select open volume control a window will open u need to check all mute option then try
Gizmo1
12helpful
8answers
Problem of video controller(VGA Compatible)
Out of the three, which one is your model.. Compaq Presario V2000 CTO Notebook PC Compaq Presario V2000T CTO Notebook PC Compaq Presario V2000Z CTO Notebook PC Please specify and also about the OS you are using?
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
Michael Thomas
Michael Thomas
Davit Mamyan
Davit Mamyan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
