Question about Stihl Garden
How to find out the serial number of my Stihl chain saw
Posted by Chester McConnell on
James pugh
    New Friend:
    Problem Solver:
  • 9 Answers
Look on the body of the saw. There should be a tag that shows model serial and sometimes family numbers.
Posted on May 16, 2015
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
What other chain can i use on a stihl 025
You need to know three things about your saw as to what chain will interchange....1. Pitch of the chain. 2. Guage of the guide bar. 3. Number of chain links.
Your little 025 Stihl wil probably have an .050 guage and a .325 pitch. The standard guages for small saws are .043, .050 with .058 and .063 being reserved typically for the larger displacement saws.
The pitch is the length of three links, divided by two and the number of links is kinda self-explanatory. (The 025 USUALLY is set up for the .325 pitch.)
Any chain that matches the three measurements for your respective saw should interchange. Hope this helped instead of adding to the confustion......
Sep 18, 2015 | Stihl Garden
What Stihl chain should actually go with this bar?
3003 001 6113
3003 Is for the 048
001 (internal Logistic number)
6113 the last indicates bar length which you already know as 25"
It for 3/8" chain.
All need to know is its gauge which can determined from the your chain's drive links number.
1 .043" 1.1 mm
3 .050" 1.3 mm
5 .058" 1.5 mm
6 .063" 1.6 mm
0 .080" 2.0 mm
Jan 17, 2015 | Stihl Garden
Stihl Chain Saw serial number 110764141, what model is this?
Tnx for replying it looks to be either a 042 or 048 series.
The main difference to the cylinder size. The 042 use a 49mm and the 048 use a 52mm. Most of the parts are still available through your local Stihl. There is no online sources except for a few aftermarket as does not allow dealers to sell parts online.
If you work with your local Stihl they should work it down even further for you.
Jan 01, 2015 | Stihl Garden
Chainsaw
I need to know the part number of the air filter cover, the fuel tank handle, and the recoil cover.
Dec 07, 2011 | Stihl Garden
Where is location of serial number on a 420 stihl cut off saw?
The Serial is engraved into the aluminum right next to the muffler. Look from the top down and you will see it. Good luck
Nov 07, 2010 | Stihl Ts 410 420 Cut Off Saw...
How do I find Stihl 041 s/n with silver sticker gone?
you cant. that is the only serial number on the machine
Apr 16, 2010 | Garden
Cant find serial numbers on stihl chain saws
For some the serial number location in the Product Instruction Manual here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If yours is not please contact Stihl here:
Contact Us
http://www.stihlusa.com/contact.php
HTH
Lou
Jan 05, 2010 | Garden
Garden Logo
285 people viewed this question
Top Stihl Garden Experts
ray gallant
Thomas Perkins
Thomas Perkins
bryan st
Are you a Stihl Garden Expert? Answer questions, earn points and help others
