Question about Health & Beauty
The hazard lights on my mobility superglide scooter work but the indicators do not the fuses are all ok
Posted by sue arnell on
ADRIAN
    Sergeant:
  • 313 Answers
This sounds like the indicator switch is at fault or a control fault.
Posted on Jun 16, 2015
4 Related Answers
paul proctor
  • 4102 Answers
SOURCE: The right hand side indicator
Hi if when you put the hazzard lights on all the indicators work then this suggests the problem is with the indicator switch, you may need to get it replaced, it could be that it has got corroded due to rain or damp getting in, if the hazzords are working ok then you know the fuse and bulbs are good so all thats left that could be wrong is the switch that works the indicators.
this will need removing and replacing to solve your problem
Posted on Aug 18, 2010
lennieg2000
  • 692 Answers
SOURCE: pride vicyory viper mobility scooter. no power no
about the only thing I can suggest is to make sure you have power out of the batteries going to the system. If you have a charger port located on the tiller take a digital volt meter and set it to 200 vdc and plug the leads into the two outter holes of the charger port with a full charge you should read 25-27 volts. If you don't have a reading at the port then there is a problem with the power getting to the tiller. It could be a bad cable Pride is notorious for developing problems in the cable going to the tiller. I would suggest you find a repair service to check the scooter for you. Maybe your provider (where you got the scooter) has a tech that can check it for you. I'm sorry I can't give you a definite answer but there are so many things that can affect a scooter: bad throttle, bad speed pot , bad cable, bad connections, bad batteries that its difficult to give you one answer that will fix your probelm Hope this helps you
Posted on Feb 16, 2011
SOURCE: on my icon 4 scooter
Hello Harold,
Please visit the link provided below :
http://site.a2bscooters.com/royaleusermanual.pdf
http://www.evrider.com/manuals/royale-3-and-4-user-manual.pdf
Posted on Apr 23, 2011
Korede Atunrase
  • 1456 Answers
SOURCE: the scooter works except horn
Hello
For the horn most scooters,the horn has voltage to it, just needs a ground to make it sound. Check the grounds and the terminals at the horn(s). Vibration may have broken the wire internally or at the terminals.
For the light pull the front panel off and make sure that the swtich wires are connected. also pull the side plastcis and make sure that all the wires coming up from the motor thru that rubber grommet are also connected.
Posted on Jun 17, 2011
Pride Celebrity XL8 - problem with right side indicators
hi Stuart, have you check out the actually switch that you pressed to activate the indicators ?
Regards
Rob
Apr 18, 2016 | Pride Health & Beauty
My dads mobility scooter wont go and the two light on the black box under the seat are not on .
A blown charging circuit fuse? The fuse may be under a floor hatch and mat and not feature in the manual - that turned out to be the case with a Pride Mobility scooter.
Jun 03, 2014 | Pride Health & Beauty
Why no lights, indicators, horn or charge indication?
hi, now i could be wrong but some models of CTM mobility scooters had a fuse on the tiller circuit board located under the tiller cover...
Be sure to remove a battery connection before looking ...
Regards
Rob
May 02, 2014 | CTM Homecare CTM HS-740 4-Wheel Power...
Batricar alpha 2000
Hi, if i remember correctly there is a fuse for that... very awkward to check so take care
Regards
Rob
www.gewizrepairs.co.uk
Mar 13, 2014 | RTO Health & Beauty
Fault light and hazard lights and horn on continuously
hi, Has it got wet ?
If so water collects at the bottom of the switches making a connection, to fix carefully remove the base of the switch and dry, beware here will be a lttle string in there plus bits of plastic... so beware...
Regards
Nov 19, 2013 | Electric Strider Midi 4 Wheel Mobility...
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
The right hand side indicator does not work on my Pride Legend Classic XL8. I have checked the fuses and they are ok. The left hand side indicator and the hazard flashers work perfectly. Please help.
Aug 18, 2010 | Pride Mobility Products Pride Legend XL -...
Electrical fault
Sounds like a problem with the circuit board under the speed pot,
It could be a loose connection and remember there can be a fuse under there.
Regards
Gewiz
Sep 26, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
95 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
