Question about BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight
I have changed the batteries on a Synergy 6500 handset but it does not charge and the display is blank. What could be the problem?
Posted by Gordon Cooper on
Steve Butterworth
  • 938 Answers
No actual idea, but check user manual, go to BT website and check there (esp FAQs). Do BT have a customer helpline?
Posted on May 17, 2015
1 Related Answer
Jerry Westdale
  • 42 Answers
SOURCE: hanged batteries in handset but phone will not ring
Check to see if ringer is set to hi. make sure ringer is turned on. Check to see if the base and the phone are syncronized.
Posted on Jan 03, 2015
Hi, my handset has lost its connection to its base, cannot see how I re-connect it. help please
Usually just re-cradle the handset for a minute. otherwise cradle and unplug for a minute, then repower the base.
Apr 19, 2016 | BT Synergy 6500 Cordless Phone - DECT -...
Ho w do I deal with power cut and flat battery?
As batteries go thru many charge and recharge cycles, they lose their ability to retain full charges. Time to buy a new battery.
Dec 08, 2014 | BT Synergy 6500 Cordless Phone - DECT -...
Why does my Phone handset says no link to base please check base?
Charge handset
Make sure there are not other signals interfering with the phone (wifi router).
Check to see if base and handset are on the same channel.
Aug 02, 2014 | BT Synergy 6500 Cordless Phone - DECT -...
BT SYNERGY 5500 HANDSET IN TEST MODE
Having changed the batteries on my bt synergy 5500 trio it now displays that it is in test mode. How can I activate my phone so that I can receive and make calls
Oct 02, 2012 | Lands Phones
Additional handset on BT Synergy 6500 phone is stuck on 'Test Mode'
is possble to use 8 bt 6500 hand phones via 2 base unit on the one bt line
Feb 28, 2012 | GE 25942GE2 Cordless Phone System
Base unit on bt synergy 3505 keeps beeping and handset keeps displaying base 1 and losing signal.... intermitent fault....have changed batteries in handset and switched unit on and off but still not...
If the handset displays 'Searching', 'Base' or 'Range out' on the screen, this indicates that the handset has lost its link with the base. The following procedure should be followed to help resolve the problem:
  • Confirm that the power lead has not been inadvertently disconnected from the base.
  • Ensure that the handset batteries are correctly installed and are fully charged.
  • Ensure that the handset and base are within range of each other.
  • Switch the mains power off, wait five seconds and then turn it on again. This will reset your product.
  • Carry out a reset procedure on both the handset and the base to return the settings back to the factory default. Your user guide will guide you through the correct procedure.
  • If none of the above remedies solve your problem, please contact the helpdesk.
Jul 20, 2009 | British Telecom Synergy 2110 Cordless...
My Nokia 6500 is not getting switched on
its problem flex if u change flex everything will be fine
or contact me [email protected]
Jan 28, 2009 | Nokia 6500 Slide Cellular Phone
I have a bt synergy 2110 cordless phone. There are 3 lights on the right hand side. one for power/in use, one for charging one for new call . All3 are lit up. How do i get the "new call " light to go out...
I may have a solution you can try.
1. Take handset out of cradle.
2. Press and hold bottom, right hand side, bottom button, marked "Calls"
3. Hold until "Display" shows number of calls, usually 10 and makes a bleep-type noise.
4. Now press top left button, marked "Del" in red, until the display scrolls through all 10 numbers and deletes all the numbers stored in the memory. The phone should then make a bleep noise.
5. Press "red handset symbol" (finish call) twice.
6. Replace handset onto cradle and the "new call light" should go out.
You should now be able to make calls.
Good luck !!!
Nov 27, 2008 | British Telecom Synergy 2110 Cordless...
No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
May 08, 2007 | British Telecom Synergy 2110 Cordless...
BT Synergy 6500 Cordless Phone - DECT - Silver Titanium 1 x Phone Line - Answering Machine - Caller ID - Speakerphone - Backlight Logo
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
NOEL
NOEL
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
