SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
SOURCE: I have a john deere 737 ztrak with a 23hp kawasaki
First. My disclaimer. I do not have first hand experience with your model mower.
Well, it sounds like when you engage the PTO the power to the PTO shorts to ground causing a) your charge light to come on as the voltage drops substantially and b) your mower to stall as the minimum voltage of the ingnition system is reached (or some other effect is at work). The clutch is might be internally shorted, or you may have a frayed wire in the PTO circuit. You may or may not have a PTO relay. If you do, it is sure to burn up if you continue using your mower. If you do not have a relay, you will definitely burn out the PTO switch. It is odd you are not blowing an inline fuse if this is the correct answer. Check your PTO circuit with a continuity tester to tell you if there is a short (or measure resistance directly with a voltmeter on ohms).
SOURCE: John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
had a similar problem. The engine mount bolt that grounded the PTO black ground wire was loose- causing the pto to work erratically. To see this bolt (13mm i think) you will have to lie on your back and look under the machine. It is above the front steering arm of the right tire. If the wire is dangling you will need a new bolt. Thanks for the previous posts ;)
I don't have a the proper equipment to pull the idler pulleys off but when I spin them by hand they do not make any grinding noises like they would if the bearings were gone.
