I had the same problem and with some pushing and pulling I got the door open again.
TURN OFF THE BREAKER....
Next take all the screws out of the door panel to access the door latch assembly. You will see the handle has plastic tabs that hold it in place which are broken. Order a new assembly and install it.
My problem was getting the wiring harness off of the switches they are clipped on very tightly so I just kept the old ones connected and put them on the new assembly.
Good luck
O
I just scoffed at Ron's answer just now. I thought, this guy must not understand the question or hasn't seen the washer we have. Then, after thinking a bit, I began wiggling the strike plate and tugging on it after unscrewing the screw on top...it pulled out and the door just fell open.
Turns out Ron's pretty much the smartest guy on this thread.
Thanks Ron! You're a genius.
SOURCE: Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
SOURCE: dishwasher door latch
sounds as if your door latch/handle is broken internally.your dishwasher is installed with 2 screws to theunderside of your countertop. its tricky but youll have to remove them (adjusting to leveling legs down will give you more room to get some kinda a phillips head bit in ther to remove the screws), once out slide the d/w foward and remove the strike plate door will open at least get your dishes out
