SOURCE: 1996 GMC Sierra 1500 truck fuel problem
Have you check the injector relay or maybe a fuse for injectors.
SOURCE: 89 chevy beretta gt- surges at idle, backfires and hesitates
Hi! I had the same problem with my 88 2.8 Ltr. Had dirty fuel Injectors. Put in fuel Inj. cleaner in gas tank, after a couple of days, runs like a dream,no more problems. Give it a try. Take care,Leo B. [email protected]
SOURCE: 1988 nissan pickup engine rotates but does'nt start.
it sounds like the injectors are not opening up man.. replace the injectores and this should fix your problem..good luck keith....
SOURCE: car won't start, little backfire through throttle body
water in the gas?
lose wire in the plugs
fuel filter is dirty
auto choke is stuck
What?????????
SOURCE: 1999 pontiac grand am 4 cylinder rough idle, rpms fluxuates
Most likely your throttle position sensor is faulty. You could have a vacuum leak as well. Most probable cause is a bad sensor. Is your check engine light on? Have you checked your engine codes? You can go to autozone.com and register for full free online repair manual.
Testimonial: "the check engine light had been on but we unplugged the battery yesterday for a couple of hours and put it back in and the light isn't on anymore. "
