We need help in getting the antenna to work. We are giving up cable and going to an external antenna ClearTV or RCA ANT702F. But we can not get a picture, just static.
Yes, we have used the MENUE, set the clock, changed tuner to antenna, and done the auto search for channels. But all we get is static.
Then you will need a converter box,there is no analog signal anymore,it was changed to digital,your tv is not hd if you dont even get one channel,you also need a hd antenna,
To get HD channels you need to have a cable/satellite box that can receive HD channels AND you have to connect that box to the TV with either an HDMI cable or component jacks. A normal cable/satellite box won't work; neither will a coax antenna cable or consolidated video (yellow RCA) plug. Hope this helps!
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
Cindy Wells (the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well.. Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
in order to listen and watch your magnavox
DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to
Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other
..pls remember,Always reverse connected ) (audio will come thru
Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on magnavox **
you need to connect "Audio Output " as can either be : RCA jacks or
"Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has
different type of Audio out jacks ) ** to "iRCA nput or "Optic Cable input" of your magnavox (whichever you want ,based on the necessary cables on your hand ) There you go..Tv/Cable box video and sound are both on the magnavox for recording..
Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections.
I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.).
http://www.dennysantennaservice.com/2029710.html
This should be of great help to you.
Happy viewing =)
have this model..was trying to hook it up to a directv hughes receiver.After a day of trying and many curse words I found that using thishookup works . Hook up your satellite connection to you tv asusual...Now plug rca cables(red,yellow white) into the corresponding holes on the BACK of the Directvreceiver ..now plug the rca cables into the FRONT of the Magnavoxplayer...you will only use find holes for the white and yellow(that'sok) Now hook up up the dvd playerto the tv using the rca connection back of dvd/vcr player..or if yourtv only has a coax connection you will need a rf modulator available atwalmart etc. You will run the dvd/vcr on L2. The key is the connectionsto the FRONT of the dvd/vcr player..I hope this helps..:)
Here is how you should have it connected. 1- Antenna (rabbit ears or whatever) 2- Converter box 3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
