Question about Sony Televison & Video
I have got a Sony cassette recorder RDR-VX 420 plus a Tv no Sony KDL 32w705b when i try to record with the Tv on the picture is fine but when i turn the Tv off the recorders a blank screen thanks
Posted by Keith Linley on
gemagm
    Master:
  • Sony Master
  • 689 Answers
Evidently you are recording from the TV. You're running the signal to the TV then out of the TV to the recorder. You should run the signal to the recorder then output to the TV.
Posted on May 16, 2015
Sony KDL 32W705B PLUS A CASSETTE RECORDER RDR-VX 420
May 15, 2015 | Sony Televison & Video
I have got a sony cassette recorder RDR-VX 420 and a Sony tv KDL 32w705b when i try to record with the tv on the picture is fine but when i turn the tv off the records a blank screen thanks
Linked below is the manual with detailed connection options and troubleshooting help. I suspect you may be using SCART jacks (that I have little knowledge of) and they work a little differently than other methods that I am familiar with. Review the connections and the Easy Setup procedures and try once more.
Sony Support
I have sony rdr vx 420 i am trying to transfer video to dvd on the machine and i cannot find the user manual, is this possible to do? i have tried pressing buttons that i thought would work but i cannot...
You may download the user guide for free support site Please find the link bellow.
Before you start, make sure to use the input button on the sony remote to select L1 or Line1 on the front panel display.
http://www.sony.co.uk/product/dvd-recorder/rdr-vx420#pageType=manual
I hope this helps :)
Mar 10, 2011 | Sony RDR-VX420 DVD Recorder/VCR
Sony vx 535 will not record dvd from direct tv channels. It shows that it is recording except on playback it is all black.
if your using a cable or satelite box it will work but has to be on the channel and powered on. dont change stations or it will record you changing the stations
Jul 09, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Cannot remove caption
Press the info button once on the HXD890's remote control (button top right on the main circle in the middle). All should then dissappear.
Nov 25, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I want to transfer material from video cassette to dvd. I have a Sony cassette recorder slv- se610g and a sony dvd recorder rdr-gx3. Can you please tell me how?
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
Aug 19, 2008 | Televison & Video
Failure to record on -R DVDs
DVD-Rs do work with the RDR-VX500 ...... I had not recorded on mine for a few months after I ran out of the last batch ....... then I tried recording on the newer Sony DVD-Rs I had ...... would not record on DVD-R ..... turns out the instructions say the recorder will not work with any DVDs faster than 8x .... It looks like it's recording but it doesn't ..... then I noticed the newer DVDs were 16x ...... found an old 8x and tried it and it works fine ..... turns out the unit won't record slower on a 16x, it just won't record at all ...... get 8x and you'll be ok
Apr 23, 2008 | Sony RDR-VX500 DVD Recorder/VCR
Can't remove AV Input display
Try setting hdmi control to off in tv menu
Apr 06, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
67 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
