Question about Nextbook Premium 8 Se Android
How do I use my SD card? My programs will not update saying there is not enough room.
    Sergeant:
  • 288 Answers
If you go into where your apps and files are listed you should have a choice to be able to move them to the SD card rather than using the tablets memory.
This may be in the " Settings " area which looks like a Cog on most android apps.
Posted on May 15, 2015
Just Purchased an All winner 10" tablet model #TD9300D says has internal storage (total 504 mb) (121 mb avail) SD card total (4.66 GB) (avail 4.66 GB) Can't download-no room no setting to sd card
The internal storage of that tablet (which I have never heard of before) is extremely tiny. You would need to delete any unused apps to free up space. I think that there are restrictions as to what can be saved to SD memory.
Feb 02, 2018 | Tablets & eReaders
After I put a new memory card in my tablet what do I do to get the tablet to not say not enough room?
You need to manually transfer memory content to the SD card, things like files and photo's for starters. This is not an automatic process.
Jan 27, 2017 | Tablets & eReaders
When i try to download a game my nobis9 says i have insuficent space. How can I get the. game to install on SD card?
You probably have to download and then mo e it. Try relocating already downloaded ganes/apps and photos to make room
Jul 20, 2016 | Tablets & eReaders
Hasn't saved anything to the memory card because his tablet won't allow him to .. It keeps saying not enough space it's a 8GB memory card
The internal memory cards of some Android devices are partitioned for app storage and installation. Some of them have partitions that are quite small such as one Gigabyte or smaller. The remainder of the storage cannot be used for apps.
If it keeps saying not enough memory space then chances are the app partition is full. The only way to free up some space is to uninstall some apps that are stored there but not being used. You can see which apps can be uninstalled in Settings > Apps and look at them one by one to see if an uninstall option is listed. Simply click *uninstall* to remove them from the app storage partition. This will free up some extra space for some new apps or for updates to older apps you still like and use.
Also some of the apps might show an option to move them to an external SD card (if your device has a slot for one and if an SD card in inserted therein). Do move any and all to the external SD card of you have that option as that will also free up that space from the internal SD card.
May 11, 2015 | Tablets & eReaders
It wont reconize half my memory so it wont let me download apps
It has very limited memory allocated for apps. It only amounts to about 661 megabytes. The entire SD card shows about 5.5 gigabytes most of which will probably be available for whatever but not for apps. Apps can only be written to the small app partition.
The unfortunate reality is if you allow automatic updates from the Google Store to update the native apps, there will NOT be enough room for them all and you will get a *no more space available* error message. So, turn off automatic updates in Settings in the Store ASAP! If you install an external microSD card in the slot in the back you might be able to move some of your apps to it using the Apps function in Settings on your tablet. This will free us some extra space on the built-in SD card. But, unfortunately, the native apps can't be moved. But, some can be disabled and some you can delete the data and the cache. But, don't delete the data on the ones you use or all your mail, accounts etc will go away and you'll just have to set it up and download mail again.
Feb 18, 2015 | DOUBLE POWER TECHNOLOGY Nobis NB09 9" 8 GB...
This tablet has 2 lots of memory,one called endeavour which has 4.83gb,and one called internal which has 142mb free.I want to update a few apps but it tells ,e I haven't got enough room! How can I upd
not exactly sure - but some tablets designate internal stg for the operating system and built-in apps and data such as address book or contacts, the settings app, etc. the endeavor stg may be the remaining available for your apps, data and media. Some updaters require extra working room to update an app - look in your settings and see if you set a default location for the apps and media you install. Another thing you can try is to delete the app and then reinstall it from the play store, the reinstall should grab the latest version. It also looks like you can add memory via SD card - probably a micro SD - 16gb is fairly inexpensive. Insert the card then mount it - look in your settings to see if you can set it as your default location or if it is offered as a choice when attempt to install an app. Some operating systems only allow media such as music, photos and videos to be stored on SD card memory - if possible, do a google search for your tablet model to find a manual.
Dec 10, 2014 | Tablets & eReaders
Sd card
The SD card is not counted as RAM Memory.
RAM memory is included inside the tablet and is not upgradable.
The ram in your tablet is RAM DDR3 512MB.
Tablet PC Android 4 2 Tablet PC 9 M9100
Apr 16, 2014 | Kocaso NEW MID M9000 9.0 " Android 4.0...
I try to download apps to sd card on archos 101directly but by default it downloded to internal memory. Can any one help how can i download throw sd card thank you
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
Apr 22, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
Nextbook Premium 8 Se Android Logo
87 people viewed this question
Top Nextbook Tablets & eReaders Experts
Scott Fryer
john smith
Lawrence Oravetz
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
