GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
J
Johanna Lopez Posted on May 15, 2015
Replace part GE Monogram Side-by-Side ZISS420NRJSS
Already diagnosed. Need help on how to replace part#WR49X10283.
  • Anonymous May 15, 2015
    Since none of us are GE parts dealers, it would sure help if you would DESCRIBE THE PART (instead of just listing the part number)!
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Mar 28, 2008
SOURCE: GE Monogram ziss480dmss Side-by-side refrigerator
no replace the door control bd or check for a loose or bad connection on the control bd also in an abstract sense one of the freezer door switches could be bad ones for the freezer light ones a safety for the door dispenser sys but that would be rare but possible
Anonymous
  • 410 Answers
  • Posted on Jan 21, 2009
SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
Anonymous
  • 46 Answers
  • Posted on Jun 26, 2009
SOURCE: GE monogram ZIS420D. freezer reading 17degs and
to much stuff in the frezzer?
Anonymous
  • Posted on Aug 19, 2009
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Anonymous
  • 1606 Answers
  • Posted on Oct 14, 2009
SOURCE: GE Monogram ZISB36DYB Freezer Not Cold Enough; Burning Center
Pull the refrig out , and remove the panel at the bottom , on the back . Behind this panel , will be the compressor and condenser " roll " coil , and the condenser fan motor . From your description of the problem , the fan motor in not operating , or the coils are extremely clogged with dust . If the fan motor is not operating , the most likely cause , is the main control board . You can try replacing the motor first , but , the board is most likely the cause . This is the electronic board , behind the 8 " X 10 " panel , behind the refrig also . If you remove the panel , and look at the board closely , You may see a burned part ( resistor ) . However , replacing the burnt part , will not solve the problem . The complete board will need to be replaced .
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Ge monogram model#Zeiss420nrjss inverter board part# wr49x10283
The Monogram series have most operational parts in the top area above the doors. I'm pretty sure the mother board is up there also on the left side if I remember right. Its basically unplugging the many connectors---remounting the new board----any plugging the wire plugs back in. If you have enough extra wire in the harness, you can un-mount the old board with the wires still plugged in and then mount the new board properly. Then just unplug each wiring plug one at a time and transfer to the new board in the proper place. Another way is to draw yourself a picture or use a cell phone and take a picture of the old board so you have something to look at for reference.
Temperature Cycles Inconsistently in Freezer and Fridge
Possible thermister our main board. Would need take readings at the board to see what the themisters are reading. If they check good then issue would be in main board
I Have a GE monogram 1989 refrig. Model BISB42EKB
The defrost thermostat is located at the left rear side of the evaporator coils. Sometimes you will have to deinstall the fan blower to access it and sometimes you can get your hands around the fan. Watch out for the plastic clips because if they are cold, they will be brittle. You can access through the front, after removing the fan and the shields surround it. Try the shields first, and then see if your hands are small enough to fit around the fan motor. Just warm the clips with a hair dryer so you don't have to replace.
1helpful
2answers
Where are the compressor fins on the GE monogram side by side
here I replaced compressor on GE Monogram. U can see how machinery compartment made on Almost all models of Monograms. Thanks. Hope that helps.
3helpful
2answers
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Top Refrigerators Experts
vince
Johnny 1000
