Question about Star Office Equipment & Supplies
Blue star inverter a/c ERROR CODE. U9 - Star Office Equipment & Supplies
Raja
    New Friend:
Error code P0 what's the complaint
Posted on Aug 02, 2017
2 Related Answers
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: Error code U9
U9 High Voltage Power Supply (HVPS) problemThe power supply is failing..
Posted on Feb 07, 2008
Everett Lin
  • 990 Answers
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Posted on Feb 07, 2009
Blue star inverter ac e6 error
e6 is comunication error. check indoor to out door connection cablr . no joint.
Oct 25, 2014 | Heating & Cooling
Kodak U9 error code. How do you clear it?
we are facing problem Kodak i4600 scanner error u9 .we replaced udds Sensor same problem.
Aug 22, 2013 | Kodak Office Equipment & Supplies
The air conditioner wasn't on and the control box was displaying a U9 error
u9 error code means there was a problem with voltage to the unit.Can be caused be either overage or a shortage. Have you had any power outages?
May 12, 2009 | Heating & Cooling
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Error code U9
hi im jules_09,are you sure its an error code?chek first all sensor on front door and other parts of the copier that has a sensor,
Nov 02, 2007 | Office Equipment & Supplies
579 people viewed this question
Top Star Office Equipment & Supplies Experts
ray gallant
Ricky Sharma
Ricky Sharma
Jean DeLauche
Jean DeLauche
Are you a Star Office Equipment and Supply Expert? Answer questions, earn points and help others
