Emerson EM2646-WH Big Button Corded Phone w/ Caller ID, Handsfree Speakerphone, 10 Number Memory, Volume Control, Flash, Hold & Redial Logo
Betty Williams Posted on May 14, 2015
Can a headset be on this phone - Emerson EM2646-WH Big Button Corded Phone w/ Caller ID, Handsfree Speakerphone, 10 Number Memory, Volume Control, Flash, Hold & Redial
Can a wireless headset be used with NEC SL1100 Phone
The NEC SL1100 phone can be used with a wireless headset, but it will require a specific type of connection.
The NEC SL1100 phone has a 2.5mm headset jack, which is not compatible with most wireless headsets, which typically use a USB or Bluetooth connection.
To use a wireless headset with the NEC SL1100 phone, you will need a USB-to-2.5mm headset adapter or a Bluetooth-to-2.5mm headset adapter.
The Plantronics CS50 wireless headset is not directly compatible with the NEC SL1100 phone. However, Plantronics offers a USB-to-2.5mm headset adapter which can be used with the CS50.
It's worth noting that some NEC SL1100 phones are equipped with a built-in Bluetooth module, which allows you to connect a Bluetooth headset directly. To check if your NEC SL1100 phone has this feature, you can check the user manual or contact the manufacturer.
It's important to check the compatibility of the wireless headset and the phone system, before making any purchase. It's recommended to consult the manual of the phone system or the technical support of the phone system provider to ensure that the wireless headset you plan to purchase is compatible with the phone system.
tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 • Cell Phones
I have a CS70 NC./ no lifter. What is the set up procedure to use my headset without lifting my phone handset. With the base plugged into the headset port of the phone.
If the Plantronics CS70N wireless headset is plugged into the headset jack on your phone, you will need to push the headset button on the phone and then the call/control button on the wireless headset.
Good luck from Headsets Direct!
10helpful
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    How to disconnect bluetooth headset from a lost phone
    I bought a Jabra Bluetooth headset, It worked fine with my phone(nokia). I lost my phone now. Now i want to use the same headset with my new phone (huawi), but i am unable to connect it to my new phone as the phone is already paired with my previous phone. So please help me with the issue and tell me is there any way i can disconnect the bluetooth headset from my previous phone??
    26helpful
    2answers
    Bh 101 bluetooth headset lost manual and forgot pairing code
    Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
    Apr 14, 2009 • Cell Phones
    2helpful
    How do I connect my h350 motorola bluetooth with my nokia 6275cel
    Try video instructions on connecting Bluetooth headset to Nokia phones on www.HandBookLive.com under Electronics category (Motorola H710 headset). It should be pretty much the same for all headsets. Watch chapter on Pairing phone to headset (Nokia example) It shows you the steps and what the phone screen will look like on your phone as you go through the steps (activating Bluetooth option on the phone, then searching for devices (headset) and finally pairing the headset with your phone.
    17helpful
    CABLE & WIRELESS CWBTH160
    To initiate pairing, put the devices within 0.5m of eachother
    Make sure phone / pc bluetooth is on and discoverable
    Make surea headset is fully charged
    1. Ensure headset is switched OFF
    2. Press and hold the talk button (big central button on front of headset) until the indicator flashes red & green alternately, then release. Headset now ready for pairing.
      Note: Headset pairing mode will time out after 5 mins.
    3. To allow phone / pc to "find" the headset, consult your phone / pc bluetooth operating guide on pairing devices.
    4. Headset should be listed on phone / pc after search has finished - highlight and select the headset.
    5. A pin or password screen will appear, you must enter 0000 and confirm.
    6. When pairing is successful, headset indicator will change to green and flash continuously every 3 seconds.
    Pairing is then complete.
    Note: Multi-pairing.
    It is possible to pair up to two phones with the headset - the most recently paired phone becomes the "primary "phone... only one phone can be connected at a time --> this function only works in Hands-Free profile. If both phones are in range, then the headset will connect to the "primary" phone first.
    12helpful
    Sync the headset
    You never said what model is your phone but the general practise is to pair the headset to the phone.how?? Make sure the headset is fully charged ,normally showing blue light depending on the brand. 1>While the phone is on ,press a button on the headset and it(headset)should show a blue light depending on the brand. 2>keep this button pressed and go to your phone's bluetooth configs and select a 'add audio divice' tab.The phone will search for for any headset in the vicinity till it finds yours. 3>Select your headset name shown on the phone and you could be required to enter password to pair,in this case most will be (0000)or (1234). Sorry had to be this long!!!!
    Top Emerson Lands Phones Experts
    ADMIN Andrew
    ADMIN Andrew
    Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
