Question about Dehumidifiers
What is a good number setting to set dehumidifier on this spring? Higher number or lower?
Posted by Teresa Salvato on
ka4iup
  • 4,062 Answers
You can start at a lower number, and then increase it as the season progresses and gets more humid. One way to adjust is use an inexpensive humidity meter to see how well the unit is working and maintaining your desired level. Many thermometers have a humidity meter included with them. When the meter shows humidity is increasing, you can raise the setting as needed.
Posted on May 14, 2015
NOT SURE IF MY DEHUMIDIFIER SHUTS OFF AUTOMATICALLY AT A CERTAIN DEGREE
Dehumidifier's control By percent room Realative Humidity Or better known as rH% , if your not sure your unit is working or even cycling properly , purchase a seperate rH meter(there not expensive) and place it in same room someplace , Normal %rH for a homes room is 70%rH set your units setting for a target of that number and use the seperate meter to verify thats what it is (takes 24 hrs) , if Meter is consistent Higher or lower a reading that whats set on unit then yes you might have a problem with your unit
Jan 13, 2015 | Dehumidifiers
I don't understand how to set my humidifier to run economically and still do it's job.
check manufacturer web site for a manual, most have them available for download
Jul 30, 2014 | Midea MDF1-30AEN3-BA4 Westpointe 30-Pint...
Whirlpool dehumidifier ad35dssi runs, but doesn't collect any water, even in a wet area. Have cleaned filters, no luck.
Glad to hear that you thought to clean the filter, as that would have been one of my suggestions. Because, it's the most overlooked.
But, there is another one that equally overlooked and is probably the number cause of your humidifiers problem. The humidity extraction level is set to HIGH. Lower it to 32 - 35%. If your unit does not have an LED Screen readout, set the control on MINIMAL.
This is what gets confusing about the use of dehumidifiers. They work backwards from what most people think. The lower the setting, the more moisture/humidity is extracted from the house. The higher the setting/numbers, the more humidity remains in the house. The higher setting would be used only in the Winter, because removing all the moisture and humidity will make the house uncomfortable.
If this wet area, you mentioned is a basement. The ambient air temperature at floor level is colder than at chest level and dehumidifiers don't work well in temperatures between 40 & 60 degrees F.
If this is the case, placing the unit up off the floor on a sturdy table, counter, etc that can hold the weight of the unit, plus a full bucket of water will generally solve the problem.
Also, be sure that you're maintaining at least 12" of clear air space on all sides of the unit. If the air flow is obstructed, the unit will run all day and not extract any water.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Whirlpool AD35USS Dehumidifier
Haier model hdn455 serial number 05021110 it runs but has never taken a drop of water out of the air, so it just keeps running
The problem, may very well be, that the humidity extraction level is set too high. Lower it to 35% and see what happens. Keep in mind, the lower the percentage of the moisture/humidity setting, the more it extracts from the household air. The higher the setting, the less it extracts from the household air.
Also, remove and check the air intake filter to see if that needs to be cleaned. It should be cleaned at least twice a week during the operating season.
Jun 06, 2011 | Haier HDN455 Dehumidifier
My humidifier dont collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 16, 2011 | Maytag Dehumidifiers
I have purchaced two maytag dehumidifiers M7DH45B2A either one works. I cleaned inside and out blew out the coils with air. Motor runs but will not take out the humidity.
You may have the humidity level set to high. Keep in mind, the higher the number on your LED screen, (if your units have LED display) the more humidity remains in the house. Lowering the numbers on the screen (to 45%), should have a better affect.
Hope this helps you. Please let me know.
May 11, 2011 | Maytag M7DH45B2A Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
The dehumidifier cuts off when it is set on 70% as soon as the compressor cuts on. i can leave it on lo and it runs.
If you're setting the humidity level on 70 % , that means you want to leave the relative humidity in the house at 70%. That's why the dehumidifier is cutting off. Your house is already at 70% humidity or higher. If you want to remove humidity, set the level lower. If your trying to make it cooler in the house or remove a lot of moisture, set it a 35 to 45%.
Hope this helped solve your problem.
Apr 16, 2011 | Kenmore Dehumidifiers
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
Dehumidifier comes on runs for hours but does not dehumidify. The water pan is empty.
is there a setting ?? Dehumidify ??? as opposed to "Fan" if so set to Dehumidify...also turn up the dial to a higher number.....Is the element in the back Cold???? If on Dehumidify . turned up high and the element is cold...then you have a refrigerant leak and not worth fixing unless its under warranty
Oct 24, 2009 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
329 people viewed this question
Top Dehumidifiers Experts
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
