Shopjimmy did a foil repair cleaned color wheel
SOURCE: Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
SOURCE: lamp light (lite the color red)
Chances are its the bad capacitor issue on the power pwb, These symptoms will mimic a bad ballast. You can get a repair kit for the V26 PWB PCB at the following link which contains the replacement capacitors and a CD which identifies the board and capacitor location that needs the capacitors changed and also contains the Service manual on that CD, and the entire kit costt less than just the service manual anywhere else. They have free tech support to help you with the repair as well. Heres the link the kits are listed under the repair kit catagory.
http://servicemanuals.vstore.ca/
SOURCE: My mit wd52525 is dead. Once
Lets access the "Error Code Operational Check" to determine where the fault came from.
Note: The TV must be in "Shut Down" and not manually switched Off, to perform the Error Code Operational Check.
When the TV is switched Off, the code automatically resets to "12" No Error.
Press the front panel "DEVICE" and "MENU" buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is "32", the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
Let me know the error code to assist you further.
Jdvillanueva
