Question about magicJack Plus
What is my pass word - magicJack Plus
Posted by Cecily Gibson on
Anonymous
It is the password you selected when you originally signed up. If you lost it, CONTACT MAGICJACK CUSTOMER SUPPORT. (Our psychics were unable to obtain your password from the great beyond, sorry.)
Posted on May 13, 2015
I can not sign in
INSTALL VERSION 10.0.....,THERE ARE PROBLEMS WITH YAHOO MESS 11.
Jul 14, 2013 | Yahoo Messenger
What are the applications of a band pass and low pass filters?
A "band pass" filter attenuates all frequencies except those in its specified range. A "low pass" filter attenuates frequencies above a specified frequency (permitting only lower frequencies to "pass"). A "high pass" filter attenuates frequencies below a specified frequency (permitting only higher frequencies to "pass").
For example, a "band pass" filter rated for 500MHz-4GHz will effectively eliminate all frequencies below 500MHz and all frequencies above 4GHz. A "low pass" filter rated at 10KHz will effectively eliminate all frequencies that are above 10KHz. A "high pass" filter rated at 70Hz will effectively eliminate all frequencies that are below 70Hz.
Jul 25, 2011 | Computers & Internet
Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw] Receiving response... [FAILED] *** ...
sometimes YM is very busy for connecting people..that is why you are unable to connect but try reconnecting again...it works
be sure your password and username is correct and your internet connection is stable...
Jun 27, 2011 | Yahoo Messenger
I can't sign in Y!M clicked troubleshooting and I got this Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the...
Bruno
Start your troubleshooting with a clean browser
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_cclean...
On the sign-in page click Messenger > Connection Preferences - make sure there is nothing untoward in the lower 2 boxes - if incorrect make changes using the drop-box options > OK
Copy this Yahoo secure site URL
https://www.yahoo.com/
Open Yahoo Messenger > Tools > Internet Options > Connection tab > LAN settings > Uncheck everything then check 'Automatically detect settings' and 'Use a proxy server' > Advanced > Paste the address in the secure box and type 5050 in the port box > OK
Sign in.
Hope this helps.
Mar 12, 2011 | Yahoo Messenger
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jan 24, 2011 | Microsoft Xbox 360 Console
Cant sign into yahoo messenger. Checking virtual IP servers... [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw]...
[VIP Raw] Receiving response... [PASSED]
[VIP Raw] Checking HTTP response code... [PASSED]
[VIP Raw] Parsing connection server IP address... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [PASSED]
[VIP Raw] PASSED *** 98.136.48.85 ***
Checking connection servers...
[CS Raw] Connecting to connection server port '5050'... [PASSED]
[CS Raw] Sending port check command... [PASSED]
[CS Raw] PASSED
Checking login servers...
[Login] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0001' ***
Aug 10, 2010 | Yahoo Messenger
magicJack Plus Logo
Top magicJack Office Equipment & Supplies Experts
ray gallant
C. David Graves
Are you a magicJack Office Equipment and Supply Expert? Answer questions, earn points and help others
