Question about Pasquini Livia 90 Espresso Machine
How do i replace a touch pad - Pasquini Livia 90 Espresso Machine
Posted by ed mitchell on
Mister Danger
  • Pasquini Master
  • 5,631 Answers
See user's manual, if any hint. Actually, didn't know that asquini Livia 90 Espresso Machine has a touchpad. Looks a really interesing device!
https://www.seattlecoffeegear.com/assets/user-manuals/pasquini/pasquini-moka-grinder-user-manual.pdf
Posted on May 13, 2015
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
My oven pad show out F2:E1
For Whirlpool (and associated brands), the F2 E1 error indicates a communication problem between the touch pad and the electronic control board. The oven's control thinks that the touch pad wiring is unplugged. This could be due to damaged wires, a loose wiring harness or a problem with the touch pad. First check that the wires aren't loose. Press Cancel to see if the signal is sent to the control board and clears the error. Wait 60 seconds for a response.
If the error persists, you need to replace the touch pad. On some models, you'll have to replace the touch pad and control board since they are sold as a single unit. For the units where the touch pad is a separate unit, you may still need to replace the control board. If the F2 E1 error persists after replacing the touch pad, then the control board is also faulty.
If you post a comment with the oven's make and model number, I may be able to give you the appropriate replacement part numbers. If your oven is still under warranty, contact the manufacturer for the repairs.
I hope this helps.
Jun 28, 2016 | Ovens
My start pad doesn't respond to pressure
Problem seems most likely damage or corroded touch pad connections inside or outside and this is common problem for most touch pads as moisture and humidity enters inside touch pad mechanism and problem can be solved with replacement of needed parts and most likely touch pad must be replaced
Oct 11, 2013 | GE 24 in. Profile PDW9880JSS Built-in...
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Touch screen not working help me
the touch pad of your phone is faulty it needs to be replaced.
To replace the touch screen, you need to get a new touch pad.
When you purchase the new touch pad,you have to loose the phone to gain access to the faulty touch pad.You will needing a soldering iron to replace the touch pad.
If you do not have the technical know how of fixing the touch pad, i would advice that you give it to an expert so that you will not damage anything further.
Have a nice day.
Mar 15, 2010 | Sony Ericsson P900
Oven does not get hot F1 F7 error message. one burner does not
Hi there
Heres the codesfor you and hope this helps and let me know.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Thank you for writing to fix ya.
Best regards Richard
Feb 12, 2010 | Magic Chef 31100 Gas Kitchen Range
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
When operating the oven I will get a beeping with the error code F-5, F-1, and F-3 should I replace this range
Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
I am receiving the same error message on the display window
Function key shorted or stuck :
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Sep 12, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Pasquini Livia 90 Espresso Machine Logo
107 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Charles Tidwell
Terry
Terry
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
