SOURCE: Lucent Tech Partner 18 phone manual
www.telemanuals.com
If the message waiting light is on. Is it lit on ext 10? If so, there might be a message in the general mailbox.
Log into voicemail
Use mailbox 9991 #
password is 123456 #
See if there are messages in there.
SOURCE: Changing greeting on Lucent Partner 18 phones
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234.If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,3 for greetings, 1 for auto attendant number, 1 for day greeting 2 for night( if your using a night key at the receptionist station then it usus the night greeting) # to go past selector codes, 1 to start recording 3 to accept greeting hang up when done
Testimonial: "Excellent info, it worked perfectly. I honestly didn't expect to get an accurate answer so quickly, thank you!!"
SOURCE: How to reset the password for a Lucent Partner 18 phone system.
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done. Your password will be the defaulted to1234.
SOURCE: We have a Lucent partner 18-d phone system.
The "18-d" is the telephone set model. The Partner System control unit is where you will find the system battery. It is located in the Processor Module - usually 2 AA batteries.
