Roland Boss BR 900cd Digital Recorder BR 900 Logo
A
Anonymous Posted on May 13, 2015
How can i transfer music to my laptap using usb cable
tommibg
Level 2:
Sergeant:
Novelist:
  • Expert 126 Answers
  • Posted on Sep 04, 2015
tommibg
Expert
Level 2:
Sergeant:
Novelist:
Answers
126
Questions
0
Helped
69080
Points
521
Connect USB cable. Computer will detect BR900, and as removable storage device. Open explorer and you can see it. Just copy and paste data, like usually doing at the computer. Copy from BR900 to computer.
you better copy the folders (all folders), instead of copying the data one by one.
ka4iup
Level 3:
  • Master 4,062 Answers
  • Posted on May 13, 2015
ka4iup
Master
Level 3:
Answers
4062
Questions
0
Helped
1096510
Points
51404
There is a complete section about this in the user manual, starting on page 161.
http://roland.com/support/article/?q=downloads&p=BR-900CD
How do I download files from my yamaha portable grand DGX-230 to my computer
To download/transfer files to computer, you need 2 softwares from yamaha website. USB MIDI drivers and MUSICSOFT DOWNLOADER.
Install drivers first,and then Musicsoft Downloader.
Connect keyboard to PC/notebook by USB cable.
Run Musicsoft Downloader.
If you click "Electronic Musical Instrument" in the Musicsoft Downloader display.and then "System Drive", a file named "08PG76BUP" will appear in the lower right corner of the Musicsoft Downloader display. This is the backup file that will transfer to computer.
Usually yamaha came with CD-ROM that contain divers and softwares + user manual,so you don't need to download.
I hope this helps.
Regards.
How do i transfer recording to my laptop
Use the USB cable and follow the instructions in the user manual. You can download the manual and updated software from here:
How do i transfer a wav file from my hd24 to a probook 4530?
Do you have a usb cable for that or for anything else or check if you have a usb cable for to a compute from that anythinh else.
Nov 28, 2013 • Music
Which midi cable or USB midi cable should I use for Yamaha DGX 520 model.
It doesn't use a USB to MIDI adapter (such as the UX-16.) It has an onboard MIDI controller and uses a standard USB A-B cable. You just need to install the driver from the CD-ROM or here, and plug it in. You can get the manual from the same page or here. Setup is on page 99.
2helpful
I want to transfer some midi files to my Casio LK-230 keyboard. When I plug in the usb cable it does recognize the casio unit but it does not show up on my computer...like there is not unit... How do...
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
How can I save my recorded track in CASIO CTK 810 IN for future use. I can record one performance but cannot save it for ever, if I record another one track the previous one is got deleted. Is there any...
Recording a new tune automatically deletes the previous one.
Solution transfer the recorded song to your computer via USB cable.
It is also possible to store up to 5 additional tunes in the song bank
See page E50 and appendix 9 of the user manual available here. http://support.casio.com/pdf/008/ctk_810_01_e.pdf
3helpful
Transfer recording from technics piano model sx-pr602-m to comput
the correct way to transfer files from the piano to a computer is via the MIDI out socket on the piano ...not the jack
you may possible need a midi to usb convertor ...which readly available and cheap
Feb 01, 2009 • Music
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
