Question about Panasonic TH-37PX60U 37 in. Plasma HDTV
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Does this tv accept hd satellite signals
Posted by Dan Atkinson on
Steve
  • Panasonic Master
  • 3,289 Answers
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
Posted on May 13, 2015
Get a satellite signal?
What does a satellite signal have to do with your router? Are you trying to get free over the air HD signals or trying to get internet on your set?
Feb 01, 2015 | Vizio 42 in. LCD TV
No signal on my bush 320GB satellite HD digital tv recorder
i have a signal while watching TV
But when i try to record it states no signal
Dec 03, 2012 | Televison & Video
I cant get a singal for my antnna
Tv does work for HD but must have cable or satellite tv signal.Yes,this tv able to play HD signal,but it is a CRT-(tube tv) design was built before the DTV switch over and never added the DTV tuner in it board circuitries.Sorry antena free DTV this tv must have to added the converter box to get the DTV free air signal.
Feb 17, 2011 | RCA P61310 TV
Is this model HD ready?
Yes,this tv is able to play HD signal,but must have pay cable or satellite signal hook it up to it.This tv is CRT-(tube tv) analog design tv,antena alone will not work without a converter box.
Feb 17, 2011 | Toshiba 50A50 50" Rear Projection...
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
WILL THIS TV ACCEPT THE NEW DIGITAL SIGNAL
Hello. All tv's accept the new signal. If you get your signal from satellite or cable, the box will make the signal compatible with your tv. IF you get your signal from an antenna, you may need a converter box, available from places like radio shack and staples.
Dec 23, 2009 | Televison & Video
Will my Mitsubishi Projection TV process HD signals?
the TV doesn't need to process the signal...the receiver will and send analog to the TV
Apr 11, 2009 | Televison & Video
I have a Sharp Aquos LC-30HV4U which is supposedly HD ready. I am a Dish Network satellite subscriber. I do not know what to do to make this HD ready set receive HD signals.
Your reciver is already set for the hd. Alls satellite programing and cable already come in hd format. You can also get any info here.
http://www.dtv.gov/
Good luck and please rate FixYa!
Apr 07, 2009 | Televison & Video
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
HD TV
In order to receive HD signals, you will need an HD receiver from Dish Network. You can buy an HD antenna from pretty much any store that sells TV stuff (Target, Wal*Mart, BestBuy, etc) which will allow you to receive over the air HD signals. But in order to get your satellite channels in HD, you will need an HD receiver from Dish Network.
Jun 09, 2008 | Televison & Video
Panasonic TH-37PX60U 37 in. Plasma HDTV Logo
129 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
