No cds on turntable table initializes correctly no cd displayed, put one cd in turn on loads cd ok, plays cd ok, if eject cd or open door cd still loaded wont unload, turntable motor runs but cannot move table as table is locked in position by cd load mechanism, comes up with table error. only way to get rid of error is to manually unwind mechanism to unload cd any suggestions
SOURCE: the cd turntable will not stay open to load/unload
the timing marks on the feeder gear and the tray gear have probably skipped a tooth from some one pushing it closed.there is a limit switch on the gear that tells the cpu to stop it.if it stops in the wrong spot,it will close after 10 seconds.take off the top cover.on the side of the tray on the right is a long track gear on the underside.there is a clip that hold it from coming out.push it and remove the tray.
check the timing marks on the other two gears .then reinstall the tray
SOURCE: My MegaStorage Sony CDP-CX250 won't play any
I would check the drive is not blown, as that is what sounds like has happened
take a 5v dc feed and run two wires to the motor to see if it spins up ,if it doesnt spin replace the motor , if it does spin then the problem lies else where in the circuitry
SOURCE: Sony CDP-CX300 attempts multiple times to load a CD but evenually reports Loading Error.
The lazer is shot end not reading the info of the disc any more,
