Question about Necchi Sewing Machines
Necchi 4825 bobbin winding problems
Cannot get bobbins to wind. Had in shop twiceHelp
Posted by Michelle Nelson on
R.A. Ellis
  • Necchi Master
  • 12,731 Answers
Or stop by the local fabric store (or even Amazon online) and pick up a standalone bobbin winder for about $25 US. You can wind all your bobbins on the little unit and not subject your machine to additional wear and tear.
Posted on May 15, 2015
Bobbin winder will not start
Take it back to the shop immediately! They should fix it at no cost!
Jun 23, 2017 | Brother Sewing Machines
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
My bobbin wonder is not engaging, how do I fix this?
In the meantime, you can pick up a standalone bobbin winder at the fabric store (or Amazon) for ~$25 US to wind your bobbins. Saves wear and tear on your machine and you also won't need to unthread your machine to wind a bobbin.
May 18, 2015 | Singer Merritt 8734
How do I wind a bobbin
The machine does it for you or you can wind it by hand but that is a lot of work take it to a sowing shop and ask the to show you how to do it that is the only way i can tell how to do it.
Dec 18, 2014 | Janome Sewing Machines
Bobbins wind unevenly- tension issues
Sounds like it is actually the tension on the bobbin winder. Make sure that the thread is following the correct path to the bobbin. Other than getting it repaired, a stand-alone bobbin winder (avlb @ JoAnn's or online) for ~$30 would work. One brand is called the Sidewinder. Verify that your bobbins will work on it because some Singer bobbins will not. It's a nice accessory to have because it saves wear 'n tear on your machine plus you can wind bobbins without unthreading the machine.
FWIW, it is usually better to wind bobbins at a slower speed. Higher speed will tend to make the bobbin jump around and the thread to pop off. In addition, higher speed will tend to stretch the thread going onto the bobbin. The thread will not relax until unwound from the bobbin and stitched into your garment. It may cause the fabric to pucker as the thread relaxes. Slower is better!
Apr 15, 2017 | Sewing Machines
My Viking Designer SE Bobbin does not stop winding
I have a Designer Topaz, very similar to yours. There is a small eccentric-shaped piece that rides the thread as the bobbin is filling. On my machine, it can be turned via the little star shaped "torx" depression. This determines the point at which the drive disengages the winding process. In the alternative, when the bobbin is as full as you want it, just push the rider away from the bobbin; the same effect is achieved.
Feb 19, 2010 | Husqvarna Sewing Machines
Require rubbber wheel for perished bobbin winding
There are lots of different rubber bobbin winder rings (tires), bring the machine to a shop and they will give you the correct one for about 1 dollar.
Feb 11, 2010 | Sewing Machines
When I go to wind the bobbin the needle still moves up and down and it will not wind the bobbin but stop beep and flash. The bobbin is as far to the right as it can go but it still is not winding.
Take it to repair shop, getting to the problem requires taking the shell cover off the machine, difficult to do, then fixing the problem might be electronic in nature.
Jun 28, 2009 | Singer 7436 - INGENUITY
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
173 people viewed this question
Top Necchi Sewing Machines Experts
tina gallow
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
